Light switch
Old May 15, 2021 | 09:33 PM
Toork's Avatar
Toork
Light switch
my light switch is really hot to the touch. The back/side, not the actual pull. Is this normal? If not, is the switch going out?
Old May 15, 2021 | 10:10 PM
obsxl's Avatar
obsxl
did you have your headlights on? the power for the headlights on these trucks runs through the headlight switch and is known to melt the switch or connector
Old May 15, 2021 | 11:36 PM
Toork's Avatar
Toork
No. Lights were not on.
Old May 16, 2021 | 07:55 AM
Toork's Avatar
Toork
After further research, I ordered a updated light harness from Amazon. My reading indicates that the harness will have the lights no longer pull power through the switch, but through relays instead.
Old May 16, 2021 | 10:56 AM
x-ring's Avatar
x-ring
Good plan. I don't know what Ford was thinking running the headlight current through the switch. Wanted to save a couple bucks I guess.
Old Jun 19, 2021 | 08:09 AM
sswari's Avatar
sswari
According to this guy, it seems like it is very common, not only in Fords.
I am looking into doing this upgrade, since reading this article.
http://www.danielsternlighting.com/t...ys/relays.html
Old Jun 19, 2021 | 03:02 PM
x-ring's Avatar
x-ring
True that, I think all the manufacturers did it up until very recently.
Old Jun 19, 2021 | 04:41 PM
Toork's Avatar
Toork
Just a FYI, the harness I ordered on Amazon came with faulty one-off relays. I contacted customer service with no response. I started a return, but they only take returns if it’s returned in the original packaging….which I trashed. 😡.
I got a different dash switch from the JY that is in good shape. I’ll run that until I make time to modify the aftermarket harness.
Don’t order it from Amazon!
Old Jun 19, 2021 | 05:57 PM
torq'ta 5 8's Avatar
torq'ta 5 8
The broncograveyard usually has them, also
Old Jun 19, 2021 | 09:10 PM
obsxl's Avatar
obsxl
The bronco graveyard harness is the same as the putco harness off of amazon and uses the same cheap relays. You can get spares from amazon or JBG as well
Vinford
Electrical Systems/Wiring
Apr 9, 2008 09:02 AM
f1fordguy
Jun 2, 2006 08:54 AM
jklimko
Oct 20, 2003 10:07 PM
Chief Ralph
Feb 2, 2003 04:03 PM
Kenny
Sep 20, 2002 11:30 PM
