did you have your headlights on? the power for the headlights on these trucks runs through the headlight switch and is known to melt the switch or connector
After further research, I ordered a updated light harness from Amazon. My reading indicates that the harness will have the lights no longer pull power through the switch, but through relays instead.
Good plan. I don't know what Ford was thinking running the headlight current through the switch. Wanted to save a couple bucks I guess.
Just a FYI, the harness I ordered on Amazon came with faulty one-off relays. I contacted customer service with no response. I started a return, but they only take returns if it’s returned in the original packaging….which I trashed. 😡.
I got a different dash switch from the JY that is in good shape. I’ll run that until I make time to modify the aftermarket harness.
The bronco graveyard harness is the same as the putco harness off of amazon and uses the same cheap relays. You can get spares from amazon or JBG as well
