View Poll Results: Stick or Auto, what have you got?
Stick/Manual
18.75%
Auto
81.25%
Voters: 16. You may not vote on this poll
Stick shift or auto?
Old May 15, 2021 | 08:36 AM
Hotcross's Avatar
Hotcross
Got to wondering how many have a stick(standard) shift or auto? I had a Cummins with a 5 speed stick and it was just so cool. With back issues I'm not able to use one anymore but would if I could.
Old May 15, 2021 | 08:50 AM
tfunk88's Avatar
tfunk88
I have an auto Excursion. Wish it was manual. Had a manual 08 F450 pickup and loved it
Old May 16, 2021 | 10:37 PM
5am's Avatar
5am
Got an 07 f250 6.0 with the auto and an 09 f350 v10 with the zf6 stick, both are fantastic trucks.
Old May 17, 2021 | 05:45 PM
Simon Espinola's Avatar
Simon Espinola
If you want to be cool, go with the stick shift
LIKE ME
Old May 20, 2021 | 11:25 AM
Byrd.Dog's Avatar
Byrd.Dog
I had a 99 7.3 with the ZF6 & hated it. Why the hell is reverse all the way to the left & up??? Hat a lot of trouble with the clutch as well. I've also had a big block with a ZF5 & really liked that transmission
Old May 21, 2021 | 12:06 PM
IHateCommieCars's Avatar
IHateCommieCars
Not sure this should be in the 6.0 forum, both because it might interest everyone (as we see here) and because there are so few 6.0s with a stick, I expect. Damn, a tuned 250 with a stick would be a lotta fun though.
Old May 21, 2021 | 05:05 PM
Hotcross's Avatar
Hotcross
I posted it in the Superduty forum also but very little interest so far.
Old May 21, 2021 | 07:12 PM
IHateCommieCars
Have you tried the AARP forum? ;-)
Old May 25, 2021 | 10:30 AM
troverman's Avatar
troverman
From what I understand, the manuals can be tough to pull loads on hills because of the lag to build boost between shifts, whether up or down. I've never driven a 6.0L manual, but I did own a 2018 RAM 3500 Cummins with the G56 6-speed manual. (I miss that truck). Power output was not drastically different than my 6.0L truck; the RAM was making 350HP and 660lb-ft and had a 3.73 rear end. I loved driving the stick, but towing a heavy load up a hill was never ideal. If you selected too high a gear and couldn't pull the hill, you'd downshift and in the time it took to clutch, change down a gear, and then release the clutch...the truck would lose boost and you might find you now were not carrying enough speed to pull the hill even in that lower gear. I generally learned to pick the lower gear and just run the hill slower. And the RAM produced 660lb-ft at 1400RPM, not 570lb-ft at 2000 RPM. The 6.0L is responsive, but it produces peak power and torque a little higher than other diesels.
Old May 25, 2021 | 01:32 PM
marker223's Avatar
marker223
HAHAHA!!
that’s so true.
billbain
Computer Chips & Tuners
Mar 28, 2005 12:01 PM
