ECT question
Old May 12, 2021 | 09:45 AM
Matt8781's Avatar
Matt8781
ECT question
Just replaced ECT becasue truck was throwing a 21 code. Still showing code after installing new sensor. I reset ecm by unpluging battery terminals for 15 min. Truck seems to be stuck in cold mode or something. Code reader is also saying code 13,21,41,22,31. After truck warms up has rough idle, blows a lot of black smoke when giving gas and the exhaust smell burns the eyes terrible. I checked the voltage to the ECT harness and got 4.62v and on ground I’m getting 0.020. Could this be a wire issue or ecm issue ?
Ps forgot to mention I replace thermostat with 195f. All that seems to be working properly coolant wise gauge does read alittle past normal but I’ve been told them old gauge aren’t 100% accurate. Truck is a 1986 F150 302
Old May 12, 2021 | 03:22 PM
Franklin2's Avatar
Franklin2
Since you have all those codes, I would say it's a wiring issue. What voltage do you get when you measure between the 5v line and the return line or ground line, not a metal ground?
Old May 12, 2021 | 07:06 PM
Matt8781's Avatar
Matt8781
I will have to check. I was checking it from a hard ground. Do I check it with the connector unplugged from sensor right?
Old May 13, 2021 | 12:08 AM
ctubutis's Avatar
ctubutis
Begin with the numerically-lowest error number, address that and only that issue, and then pull the codes again.
You also need to differentiate between KOEO & CM.
https://www.google.com/search?client...=obd-i+code+13
Old May 13, 2021 | 05:29 AM
Matt8781's Avatar
Matt8781
The link you have at the bottom looks like it’s for GM and says code 13 is o2 sensor. Everything I see says code 13 is for IAC. Should I start there anyway?
Old May 13, 2021 | 07:32 AM
ctubutis's Avatar
ctubutis
No, don't use that one, I was lazy last night and just googled. I usually send people to The Ranger Station's instructions, try this stuff:
https://www.therangerstation.com/tec...gitcodes.shtml
Old May 13, 2021 | 07:28 PM
Matt8781's Avatar
Matt8781
Hey Franklin 2 when I measure between 5v signal wire and ground wire I get 4.65v unplugged.
when I measure wires plugged in I get 3.58v
does this sound right?
Old May 13, 2021 | 07:39 PM
Matt8781's Avatar
Matt8781
And I forgot to mention I tested it on a cold engine. Haven’t started it up in few days
Old May 15, 2021 | 07:33 AM
Franklin2's Avatar
Franklin2
xxxxxxxxxx
Old May 15, 2021 | 07:39 AM
Matt8781's Avatar
Matt8781
I will have to check today. If they are the same does that possibly mean a ecm problem? Around what voltage should the sensor be at cold engine?
Old May 15, 2021 | 07:45 AM
Franklin2's Avatar
Franklin2
I had to go back to the book to see what it says about this. They said the first thing to check is the 5v reference signal to the throttle position sensor. If it's no good (we know that it is not) and then go back to the computer and check it there with everything still plugged in. If it's not 5v coming out of the computer, the computer may be bad. Here's a diagram of it.
Old May 15, 2021 | 07:48 AM
Franklin2's Avatar
Franklin2
Looks like 5v is pin 26, negative is pin 46. See if you can poke those wires while they are still plugged in. Pin 26 is orange/white and pin 46 is black/white.
Old May 15, 2021 | 05:00 PM
Matt8781's Avatar
Matt8781
So I done some testing today on the ECT. After running for 25 min the voltage on the sensor was 1.45v. Shouldn’t it be lower than this? Also I checked other sensors and they are all receiving 5v(TPS,MAP). The ECT only reading 4.65v. Haven’t poked wires on ecm yet but did do a visual inspection on ecm itself and board looks super clean and no signs of corrosion or burnouts. Wondering if it could possibly be just a new BAD sensor 🤷🏻‍♂️
Old May 15, 2021 | 08:51 PM
Franklin2's Avatar
Franklin2
You can unplug the temp sensor and take a ohm reading on it. The guy in the book has a chart with approximate ohm readings at different temperature. He said it doesn't need to be exactly these numbers, but should be in the neighborhood.
degrees F--- resistance in ohms
50--- 58,750
68--- 37,300
86--- 24,270
104--- 16,150
122--- 10,970
140--- 7,700
158--- 5,370
176--- 3,840
194--- 2,800
212--- 2,070
230--- 1,550
248--- 1,180
Old May 16, 2021 | 04:05 PM
Matt8781's Avatar
Matt8781
Exchanged sensor for a new one and seems to be working now. Now gonna tackle code 22 MAP sensor out of range.its a new map sensor🤦🏻‍♂️. And also instead of code 41 I now have code 42 says running rich. Wish me luck
Da_Lariat_Chariot
16
Dec 22, 2017 08:34 AM
bedwards
Jul 8, 2016 07:49 AM
andysam
Mar 17, 2014 02:50 PM
Skattracker3
Feb 28, 2014 07:55 AM
91ford_ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 29, 2004 11:42 PM
