Sponsored by: Real Truck
Zf6 problems, help or advice asap
Old May 11, 2021 | 04:03 PM
Diego Arturo Aguilar's Avatar
I recently bought a 1999 f250 7.3 with a zf6, I noticed as I pressed the accelerator the engine would rev but not that much power. Then rpms would go down after a second or two and would accelerate right, just changed the fluid and still is acting the same, clutch feels fine and is going in and out of gear great.
Old May 11, 2021 | 07:13 PM
jarayzener's Avatar
jarayzener
Trailering
There's not much to go wrong with manual transmissions when compared with automatics; Have you pulled trouble codes from the ECM to see if the computer is seeing a problem with something? If you don't have a code scanner, most auto parts stores will check codes for free.
Sabgut
21
Jun 1, 2017 02:52 AM
gaboy88
Sep 28, 2012 06:52 AM
John A. Yusko
Dec 9, 2010 07:31 PM
tbone681
Oct 25, 2010 03:20 PM
ollie21b
Apr 11, 2006 10:39 PM
