LED Headlight Upgrade
Old May 5, 2021 | 11:17 PM
Steve F's Avatar
Steve F
I've had my 2021 F350 XLT 7.3 Godzilla with dual batteries for a few weeks and plan to upgrade the headlights to LED H13 replacement bulbs, not the OEM LED modules found on the top level trucks. There doesn't appear to be a lot of room behind the headlights, I can't see directly behind either side to tell for sure. Most of these replacement bulbs have cooling fans that protrude out the back. I did a similar upgrade with my previous 2011 F350 and experienced bulb failure after just 6 months. I admittedly bought cheap bulbs. So I'm wondering if anyone else has done this and can recommend a reliable bulb known to fit the available space? By design LEDs are supposed to outlast halogen but I didn't experience that in my 2011. Thanks!
Old May 6, 2021 | 06:14 AM
quadna711's Avatar
quadna711
I have seen a lot of favorable reviews for the kit from https://www.f150leds.com/
Old May 6, 2021 | 06:20 AM
Poncho450's Avatar
Poncho450
On the passenger side, the entire air breather snorkel will pull out for easy access. On the driver side, you can remove the filler neck on the washer fluid tank. Still tight, but you can get in there and do it.
I also have a dual battery 7.3.
I had Beamtech bulbs in a 2017 & 2019 but I went with Hikari for my 2020. Improvement for sure.
Amazon Amazon
Old May 6, 2021 | 06:30 AM
Smindustries's Avatar
Smindustries
Please read this first:
https://jalopnik.com/why-most-led-he...-ex-1843070472
Old May 6, 2021 | 09:33 AM
Great Danes's Avatar
Great Danes
I used these bulbs from VLEDs and with the cooling fans, they fit fine. I am very happy with the light output and pattern.
Old May 6, 2021 | 10:45 AM
mhoefer's Avatar
mhoefer
LED lights in an incandescent housing are generally quite difficult to manage because the point source of light is on one flat surface, rather than coming out of the bulb 360 degrees. Very important to have LED bulbs which can be aimed, levelled in the housing. Low vs high LED point source alignment. Usually they have a very small set screw, its tricky, but aiming on a wall, matched to the previous bulbs and proper height adjustment is important. May well already know this with your experience with previous trucks.
Old May 6, 2021 | 11:07 AM
2020STX250's Avatar
2020STX250
I put a set of beamtech fan cooled leds in my 2020 about 2 weeks ago. So far I'm pretty happy with them.
I can definitely tell a difference in how far down the road I can see.
So far I haven't had anyone flashing me that I'm blinding them and I'm on 2 lane roads a fair amount.
Old May 6, 2021 | 11:27 AM
AMEC Electric LLC's Avatar
AMEC Electric LLC
I have been using the S-V.4s from Headlight Revolution. The difference is staggering.
Old May 6, 2021 | 05:48 PM
Steve F's Avatar
Steve F
Thanks everyone for your comments, I'll sort through them later tonight. I read the linked article and was aware of the shortcomings of some bulbs, I studied parabolic reflection a bit in college and get where he's coming from. I don't have the funds for the factory LED housings and I live in an area that is densely populated with deer. My old eyes need all the help they can get at night to see hazards. The factory lights on my 2011 were about the worst I've ever experienced, to their credit the 2021 is quite a bit better. I'll do a follow up when I make a decision, I'm open to more suggestions. Thanks again!
Old May 6, 2021 | 06:57 PM
Joe Kelley's Avatar
Joe Kelley
Amazon has Katana H13 9008 bulbs ... two sets $49.99 each and I would also get the fogs which are h10's 1 set for 25.99. It took me about two hours to pull off the grill and change them out, now that I know what I am doing babe a half hour next time. You need a deep socket 10mm to get the bolts off the back of the grill at the top and I used a hand socket driver to get at the bolt on the side of the bumper everything else is straight forward. The katanas are the same as the Sv4's at a fraction of the price, someone else here said that they are made in the same factory and Headlight revolution just brands them and marks them up. The difference is amazing.
Old May 7, 2021 | 04:40 AM
cabindoc's Avatar
cabindoc
I had Beamtech bulbs in a 2017 & 2019 but I went with Hikari for my 2020. Improvement for sure. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I can second the vote for Hikari. I put them in both my 2011 and 2012 and they are stout for sure. I'll probably put a set in the 2021, thats why I'm reading this thread....
Old May 7, 2021 | 08:14 AM
BillyE's Avatar
BillyE
This is the good advice if you haven't gone through this before.
Old May 7, 2021 | 08:16 AM
Poncho450's Avatar
Poncho450
Why I like the Hikari over my previous Beamtech. No set screw. Turn a dial to get proper orientation.
And setting the height is also very important. Generally needs to be lowered as a courtesy to oncoming traffic, yet still a big improvement over halogen.
Old May 7, 2021 | 09:23 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
If recent LED innovation trends that the aftermarket has already made available for other popular vehicles offers any guidance, then it seems reasonable to expect that the aftermarket might come up with full replacement headlamp housings that are purpose built for the LED lamp assemblies included with them, that would fit the needs of those who don't want to be bothered with baking their headlamps apart or fiddling with retrofits.
With OEM LED's being so expensive to buy as parts, or only available with expensive trim packages, it seems likely that the aftermarket will see and seize this opportunity to fill this demand. Judging by previous model years, and other vehicles, it sometimes takes a couple of years before these alternatives become available.
Old May 7, 2021 | 10:08 AM
TB250's Avatar
TB250
Originally Posted by Y2KW57
... it seems reasonable to expect that the aftermarket might come up with full replacement headlamp housings that are purpose built for the LED lamp assemblies...
One company has. Check out the Morimoto thread (https://www.ford-trucks.com/forums/1...pre-order.html). Unfortunately, greed rears it's ugly head and Morimoto is using the
cost of the factory LED headlight as the basis for pricing their headlamp housings.
