Opinion please !
Old Jul 9, 2021 | 08:07 AM
  #31
Alainle's Avatar
Alainle
Update July 9, 2021
Our Ford dealership changed all 4 tires, balanced (Road Force) and aligned. They looked at the drive shaft. Test drove with mechanic, he said it will be very difficult to correct the vibration. He said ‘It’s a truck, they do not run like cars’. I wanted to drop him off in a field In conclusion: no solution here. Tried to speak directly to an engineer at Ford, not possible, referred back to dealer. Dealer will buy it back and has ordered a new 2022.
Old Jul 9, 2021 | 08:18 AM
  #32
Lin19687's Avatar
Lin19687
Veteran: Navy
Originally Posted by Alainle
Update July 9, 2021
Are they buying it back due to the vibration? How bad is the vibration?
It almost seems like the dealer didn't do anything but I wonder what they are not telling you. No way Ford would buy back a truck due to a slight tire issue.
Can you tell us what the Written Reason is for the buy back? Just curious because they only replaced my fronts not the rears because I didn't want to have to wait another 2000 miles for them to say it's the same and also run bad tires on the back. That's a safety issue.
Old Jul 9, 2021 | 08:28 AM
  #33
Alainle's Avatar
Alainle
They are not buying it back because of the vibration, the high value of used trucks makes it worth changing now.
Old Jul 9, 2021 | 08:31 AM
  #34
redford's Avatar
redford
FTE Leadership Emeritus
Update July 9, 2021
Anytime they start with the "this isn't a car" story, ask them to grab a new vehicle on the lot for a test drive. I'll bet it doesn't have that same vibration.
It just irks me when somebody uses the "it's very difficult" excuse to avoid doing a job.
Old Jul 9, 2021 | 08:44 AM
  #35
losttrail's Avatar
losttrail
I change the oil every 5,000 miles and have the tires rotated with each oil change. Bought this 2019 in Colorado with just over 32,000 miles on it and experienced death wobble shortly thereafter.
Had factory Goodyear crap tires that were close to being worn out. Sadly all 4 OEM shocks were also shot. Dealer here in MT had the first shot at DW fix, so I bought new tires and they replaced shocks under warranty, so still crap OEM shocks.
Not going to worry about upgrading shocks or anything else since the 2022 is in the que and should hopefully arrive around Sep 1.
UGA33
6.7L Power Stroke Diesel
Oct 25, 2014 10:03 AM
carterjr
May 17, 2012 10:31 PM
NW 150
Jul 25, 2011 05:21 AM
RFD_Truckie
23
Jul 8, 2009 03:06 PM
Ford Fx4
2004 - 2008 F150
30
Jun 3, 2009 10:07 PM
