Opinion please !
Old May 6, 2021 | 03:15 PM
Alainle's Avatar
Alainle
Thanks everyone for your insights. Now working with the dealer and Ford to solve the issue.
Old May 12, 2021 | 05:57 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
Did they figure it out? I'm hoping to hear from you before I bring mine in now that my truck will be a daily driver for a while.
Old May 12, 2021 | 07:12 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
I never say never, but to date I've seen exactly *1* bad Michelin tire?
Old May 16, 2021 | 07:57 PM
Alainle's Avatar
Alainle
We will be changing all four Michelin tires and realining at the same time. Will update results.
Old May 21, 2021 | 05:59 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
Not sure if it is done yet, but wondering if everything is better.
Old May 29, 2021 | 06:56 PM
Lin19687's Avatar
Lin19687
Veteran: Navy
Dealer said my tires were not on the TSB but will have Continental rep come out to check out my tires .
I have the same wear as the poster but the beginning of it and still hear the wobb wobb sound like it's out of balance but alignment feels straight.
I'll update on here too for @Alainle
Old May 30, 2021 | 08:37 AM
Alainle's Avatar
Alainle
Update: I have an appointment this Wednesday ( June 2) at my Ford dealership. Will let you know what the results are.
Old Jun 9, 2021 | 04:30 PM
Lin19687's Avatar
Lin19687
Veteran: Navy
I have still not heard from my dealer about the rep.
Old Jun 9, 2021 | 05:50 PM
CBass2288's Avatar
CBass2288
4wd Low
Yeah I would start with an alignment and see where that takes you.
Old Jun 9, 2021 | 08:46 PM
Alainle's Avatar
Alainle
No news yet, still at Ford dealer.
Old Jun 10, 2021 | 12:03 AM
pig9r's Avatar
pig9r
I just rotated mine at 7500 miles and noticed similar wear on my fronts. I am running 60 psi. I am planning on getting an alignment and see if that helps. I have noticed nothing as far a drivability or vibration. I do have some steering wheel offset towards the crown of the road.
Old Jun 10, 2021 | 05:45 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
Mine was aligned at the dealer.
Old Jun 10, 2021 | 09:18 AM
  #28
17 Oaks's Avatar
17 Oaks
Originally Posted by Crotchety Ford truck only
Excessive toe in
X 2 and maybe just a bit over inflated +2-4 lbs?
Old Jul 9, 2021 | 05:44 AM
  #29
Lin19687's Avatar
Lin19687
Veteran: Navy
Hope you get this as I am curious what they said?
Mine replaced the fronts, backs went to front and new on the rears. They said they did Road Force Balance on all 4 but I am still getting that light vibration and off balance sound. I have appt at Sullivan Tire to get the Lifetime Alignment ($220 ) and will see how it feels after. If I am still getting that sound and if I get that wear I will make Ford replace them and find out if there is something else that may be wrong with the front.
No it is not over inflated, truck says perfect on the dot cold psi for all 4 tires
Old Jul 9, 2021 | 06:38 AM
  #30
Germanrazor's Avatar
Germanrazor
Hmmmm, no report back. Hope it was fixed to your satisfaction.
