FE rebuild options??
Old Apr 29, 2021 | 08:25 PM
1973f1OO's Avatar
1973f1OO
Originally Posted by 85e150
The book listed above is a good idea, and review a bunch of threads here as well. Once you get the parts figured out, being aware of assembly issues and tricks is important.
If you can swing it, a roller cam will eliminate the wiped out cam problems people have been having with flat tappets and current oils.
For your extra money you pick up a few HP to boot.
Awesome, thanks a ton. I sure learned a lot today.
Old Apr 30, 2021 | 09:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by 1973f1OO
Hey guys, I am really new to FTE and this is only my third post on here.
First, WELCOME to FTE!
These guys will be happy to spend your $'s for you
I concur on the roller cam - if you can swing the money, do it. It will give you a long-lived engine and no worries about wiping out the cam.
Old Apr 30, 2021 | 11:12 AM
1973f1OO's Avatar
1973f1OO
Alright I definitely will get a roller cam then. And thanks for the warm welcome, so far FTE is great. I've learned a ton already.
Old Apr 30, 2021 | 01:58 PM
dubya TF's Avatar
dubya TF
Thanks, I will look into doing a compression test. But, I do know it definitely has to be rebuilt because apparently the crank bearings are worn. He says I can drive it for the next year or two, but I should really rebuild it. It runs fine enough that I can drive it for the summer, but I would just like to have it start easier, idle better, and perform better too. It is incredibly slow. Not to mention mileage and reliability.
I wouldn't buy another part until you determine the current engine's condition. There's no possible way to know any engine bearings are shot without complete tear down and careful inspection/ measurement. Fuel mileage and FE will NEVER go together. Reliability and power however go hand in hand with a proper setup and tune of what you have already. A compression test, leak-down test, setting timing accurately with constant clean fuel and a strong ignition system will get you off to a good start.
Old or original harmonic balancers are known to shift the outer ring due to the inner rubber band becoming dry rotted and cracking. This will throw off your timing marks on a timing light and make tuning it futile. You can find plenty of posts on this topic on here.
Checking on your distributor itself can yield easy tuning improvements also. Lots of threads on here about adjusting points or even replacing it with Duraspark or PerTronix Ignitors.
Lastly your carb and fuel pump condition needs detailed attention that could fill volumes of threads.
Most importantly take your time, take lots of notes, get that book mentioned prior and do lots of research!
Old May 1, 2021 | 02:03 AM
1973f1OO's Avatar
1973f1OO
Thanks for the advice. I plan on rebuilding it next fall anyway, so I will continue to tinker with it until then. I will definitely see about that timing issue, because somehow my engine still pings at high rpm, even with the incredibly low compression.
1973f1OO
13
Apr 29, 2021 08:23 PM
Dads
Aug 23, 2020 02:03 PM
cdposey
Jan 27, 2012 09:00 PM
Saidyene
Nov 3, 2008 12:32 PM
Azguy54
May 15, 2004 10:55 PM
