All my searching has been fruitless to this point so why not throw it out there- has anyone heard of or seen a F100 FE t-stat water neck for the 2" upper hose with a threaded temp sensor bung? My original looks like this dude...
I guess my alternative is to switch it all to the later FE smaller upper hose correct?
The reason for this debacle is my electric fan runs a specific ohm sensor for the relay and I want to also run the original sensor for my dash.
I bought a generic thermostat housing from autozone for my 390fe and I think it was offered with and without a threaded plug. I don’t think that hole is for a temp sensor but it will work. Make sure whatever you put in this location doesn’t need accurate temps since it the thermostat will be restricting flow until the engine side opens up.
