Charging both batteries.
Old Apr 29, 2021 | 07:55 AM
Hotcross's Avatar
Hotcross
Whats the correct and safe way to charge the two batteries on a diesel? In the past I have charged each battery with a smart charger but I'm not sure that's the best way to do it.
Old Apr 29, 2021 | 07:59 AM
bismic's Avatar
bismic
IF the wiring is good (both pos. and neg. cables), and IF BOTH batteries are good, you can charge them both by hooking up the charger to one battery.
Old Apr 29, 2021 | 08:54 AM
TooManyToys.'s Avatar
TooManyToys.
As Mark said, as long as cabling is good, either way works with good batteries and will take the same amount of time. I'll do both for a routine top-off, but twice a year I like to do them individually and check their capacity.
Old Apr 30, 2021 | 02:51 PM
diesel_dan's Avatar
diesel_dan
I wrote to CTEK and asked this question, but framed with three possible charger hook-ups and leaving the batts connected in parallel (I also told them exactly what cabling mods I've made).
Here's the 3:
1) connect the charger to the passenger batt. Pos. and the ground to the Alternator leg.
2) connect the charger direct to the battery and then rotate which battery I charge (connect to).
3) connect the charger to the positive of one battery and to the neg. of the other battery - as it turns out this is a not-possible connection for my MUS25000 as the cables won't reach both at the same time.
Their answer back was all three were perfectly fine ways to charge. So I'm mostly doing #1 and once in a while go direct to the driver's batt, just "because"...
Old Apr 30, 2021 | 11:32 PM
2004 F450's Avatar
2004 F450
I use #3 with a Batteryminder on the 8 amp setting 24/7.
Old May 1, 2021 | 10:48 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Again, any of the above 3 is good. Once fully charged, or after I have driven it until charged I have a cheapy solar panel I plug into the power point and leave it as I just do not drive it enough anymore. It sets a lot undriven and I found that the solar charger keeps it charged well. I have left it sit for a few weeks at a time (Yeah, I know - not good, but....) and it starts right up every time ! Where it is parked is in full sun every day. And even when it's cloudy the red charge lamp is showing it's charging. This will ONLY work after the batteries are FULLY charged ! The solar charger is only a battery MAINTAINER !
It's MY way and it works for me. BTW, I also do this on my Lincoln MKZ Hybrid.
balingwire
Aug 21, 2023 07:12 PM
Money-Pit
Jun 5, 2020 09:18 AM
RedfireSVT
Sep 16, 2016 11:52 AM
Mulepick
Jul 31, 2011 04:30 PM
wingerpaul
Nov 1, 2008 12:07 PM
