Sponsored by: Real Truck
best battery?
Old Oct 28, 2011 | 10:07 AM
balingwire's Avatar
balingwire
best battery?
It seems that 7.3L Powerstrokes in SuperDuties require hot batteries to crank in cold weather. After difficulty cranking on morning, Advance Auto checked the batteries and one tested weak - around 600 CCA. The other tested fine. If only one battery is replaced, will this be fine? All of the charging tested ok. Also, what brand battery would be best for this truck. Dad always buys Motorcraft batteries for his Powerstroke. I drive a gas, so I get Wal-Mart because Wal-Marts are everywhere, open 24/7, and have a good return policy - I drive a lot all over, so they work for me. However, I didn't see a comparable battery in CCAs compared to the one currently in the truck. Thank you.
Old Oct 28, 2011 | 10:25 AM
cartmanea's Avatar
cartmanea
Always replace batteries in pairs unless the other is very new. Motorcraft batteries are pretty good and they last a long time. I have Interstate batteries and they are also hard to beat. One thing to keep in mind, higher CCA ratings means a less durable, shorter life battery. They use a more porous lead to increase surface area to achieve those CCA ratings. If you look at Motorcraft batteries, you'll see the diesel batteries are a 650 or 750, whereas the Interstates I got are 875.
Old Oct 28, 2011 | 10:56 AM
balingwire's Avatar
balingwire
I tend to overthink decisions. You say the higher CCA batteries tend to have a shorter life, but you went with higher CCA batteries rather than the 650 and 750 CCA Motorcrafts, so to you, does the higher CCAs justify the shorter life. (I've always tried to get the highest CCA battery that I could find).
Old Oct 28, 2011 | 10:58 AM
balingwire's Avatar
balingwire
Also, between Motorcraft, Interstate, Deka, Diehard, Duralast, then the Wal-Mart brand, what would your top 3 be? Thanks.
Old Oct 28, 2011 | 11:13 AM
cartmanea's Avatar
cartmanea
I went with the Interstate batteries because I know they are a good quality product and I didn't know the details on CCA vs durability. My next set of batteries, however, will probably be Motorcrafts.
Old Oct 28, 2011 | 11:59 AM
dagren99's Avatar
dagren99
Been happy w advance auto's gold line of batteries - longer warranty & free replacement with in 36 months sold me. Diesel's are hard on batteries - 4.5 yrs is the longest a pr has lasted in my 00
Old Oct 28, 2011 | 12:02 PM
dkf's Avatar
dkf
I like the Duralast batteries from Autozone plus they have a good warrenty. The Gold has 850CCA, 1000 @ 32 deg F. Have 5 Duralast batteries currently in service blue, red and gold.
Old Oct 28, 2011 | 12:12 PM
cartmanea's Avatar
cartmanea
Originally Posted by dagren99
Been happy w advance auto's gold line of batteries - longer warranty & free replacement with in 36 months sold me. Diesel's are hard on batteries - 4.5 yrs is the longest a <acronym title="Page Ranking">pr</acronym> has lasted in my 00
We finally replaced the original Motorcraft batteries in my Dad's '03 6.0L this spring, and they were still going strong. 8 years is pretty dang good, and that's why my next batteries will be Motorcrafts.
Old Oct 28, 2011 | 12:19 PM
azgard's Avatar
azgard
I've heard some pretty consistent good opinions on diehard platinum series batteries, they are AGM type so a bit pricey but rated at 930 CCA.
Old Oct 28, 2011 | 12:29 PM
bill64's Avatar
bill64
I put a diehard platinum in my 08' and love it. it cranks over just fine when the temps are below zero where as the motorcraft battery just barely started it.
Old Oct 28, 2011 | 12:35 PM
cartmanea's Avatar
cartmanea
Keep in mind, your gasser only has one battery, so a higher CCA rating will have more benefit. A diesel, with two lower CCA batteries in parallel, will have a lot more CCA than your single.
Old Oct 28, 2011 | 12:43 PM
dagren99's Avatar
dagren99
I only got 3.5 yrs out of my original motorcrafts - 4.5 out of the next set, a couple of years out of a pr of napacrapas, then switched to the advance auto gold's this last time. Had them about a year - so far so good. Would have went back to motorcrafts but the prev set of batts (napas) crapped out on a sunday and advance was the only game in town.
Old Oct 28, 2011 | 02:47 PM
mwsF250's Avatar
mwsF250
The best? That would be Odyssey. Hands down. Without a doubt. Worth every penny if you can justify them.
The best flooded acid battery under $200? For the last few years I have had best luck with the high end batteries made by Johnson Controls, and for the last few years, they have been consistently sold as Motorcraft, DieHard Gold, Duralast Gold, top line Bosch, and Interstate.
SOME of the high end Wal-Mart and Kirkland batteries are as well. But they are known to constantly switch manufacturers to eke out a few more cents of cost, and sometimes the manufacturer will dumb down the battery to hit cost targets. Kind of like buying no-name gasoline. Sometimes it is the same good stuff the name brands get, sometimes not.
Old Oct 28, 2011 | 02:57 PM
dagren99's Avatar
dagren99
The autocraft gold (advance auto house brand) batts are made by johnson controls too. Looks like the silvers and the standard autocrafts are sometimes from exide not JC.
Old Oct 28, 2011 | 03:11 PM
kawkx500's Avatar
kawkx500
i have the v-10 in my super duty, and i have always used the everstart-maxx battery from walmart in my truck and in every car since they started making that brand. I have never once had a problem with any of them. I just replaced the one in my truck after just a few months shy of 6 years. The battery is still going strong, actually the only reason i changed it was because i needed a battery for my off-road only cherokee. No point in putting the new one in an off-road only toy so i bought the new one for the truck and used the old one for the cherokee.
