Building 4r100
Old Apr 28, 2021 | 10:32 AM
2001plt7.3's Avatar
2001plt7.3
Building 4r100
I am looking to build a 4r100 out of a 2001 7.3 f250. Truck has a bigger turbo, injectors, and a tune. Truck tows regularly. I am looking at buying a normal overhaul kit but also buy upgraded clutches, steels, and a tourqe converter. Where should I start
Old Apr 28, 2021 | 11:28 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You should start with an upgraded overhaul kit. If you buy a stock one and then upgrade the clutches and steels you will be throwing away most of the rebuild kit.
Old Apr 28, 2021 | 11:33 AM
2001plt7.3's Avatar
2001plt7.3
Are kolene steels worth it? I have also seen a lot of people talking about Borg warner clutchs or raybestos, anyone have any experience with them?
Old Apr 28, 2021 | 12:35 PM
FordTruckNoob's Avatar
FordTruckNoob
Is your objective to build the transmission yourself so you have a stronger transmission that you know exactly what is in it, or is it simply to have a stronger transmission? If it is the latter, I suggest buying a BTS. I have been very happy with mine.
Old May 3, 2021 | 01:51 PM
2001plt7.3's Avatar
2001plt7.3
I am looking to rebuild it myself stronger because this truck has 348k miles and is already on tranny number 3 or 4
TriednTrueFordBlue
Dec 5, 2015 04:15 PM
f350idi
May 29, 2012 10:49 PM
86sixbanger
May 21, 2012 11:52 PM
85F-350Dually
Jun 2, 2010 03:34 PM
Duck Hunter81
Jan 20, 2010 10:51 PM
