e99 van donor
Old Dec 5, 2015 | 10:46 AM
TriednTrueFordBlue's Avatar
TriednTrueFordBlue
e99 van donor
So my 95 7.3 with 131k needs some attention. Hpop is weak, up pipes are leaking, turbo comp wheel is chewed and im sure my injectors o rings are worn. I have very little money to throw at it. I'm looking at an e350 with an e99 7.3 that im thinking about buying as a donor. Hoping to use the turbo/pedestal, injectors (I know I'll need a tune) and hpop? Worth it or should I hold out for a 99.5+ as I want the ease of turbo removal offered by the SD 7.3
Old Dec 5, 2015 | 12:57 PM
z31freakify's Avatar
z31freakify
Why not just rebuild your existing turbo? If you remove your up- pipes they might be reusable just get some new donuts and have them expand the pipes from where the donuts will lay. As for injectors it would be easier to send one at a time to Jim at Rosewood diesel for a stock rebuild.
Old Dec 5, 2015 | 01:00 PM
TriednTrueFordBlue
The SD turbo is a better turbo and the injectors are 120cc vs obs 90cc
Old Dec 5, 2015 | 01:11 PM
z31freakify
The injectors are still splitshot wich suck, turbo is not all that great either they flow the same as the obs just spool a bit quicker.
Old Dec 5, 2015 | 04:15 PM
ReBilld's Avatar
ReBilld
Sounds like a lot of abnormal wear for a PSD with only 131k on it. Have you verified for sure that you have all of those issues?
psd96
Jan 5, 2026 05:54 AM
JPD Motorsports
May 4, 2012 04:48 PM
Spool&Go
Oct 10, 2011 01:09 AM
Pigeon
Feb 26, 2006 11:03 AM
Mikey85
Jun 12, 2005 10:56 PM
