460 Engine overhaul question
Old Apr 27, 2021 | 03:56 AM
Jaybird90's Avatar
Jaybird90
so in a couple weeks i will be getting my 460 freshened up. anyone have a good parts list i can go off of? i have a good idea but want to make sure i have everything before i start. leaving everything basically stock but taking it down to the short block. so far i have gaskets and seals, oil pump, timing chain, water pump, front and rear main seals, spark plugs and wires, fuel injectors, distributor, harmonic balancer, starter, thermostat, PCV, new ARP head bolts and kit. also getting new dual exhaust and debating on regular manifolds or long tube headers? any additional ideas? am i missing anything? thanks
Old Apr 27, 2021 | 03:47 PM
kevinv10's Avatar
kevinv10
Cam, lifters, and pushrods. You're already that far into it. As for exhaust, I run a Banks headers into their exhaust, with a magna flow catalytic converter. Works great. Also consider deleting the Air pump system entirely. But, keep the EGR system.
And a little tip, when you pull the engine apart. Get zip-loc bags, and a sticky note pad. As the bolts or fasteners come out, put them in the bags, and write a note what they are for, and what size wrench. Really helps on re-assembly!
Old Apr 29, 2021 | 06:57 AM
Zrt1200's Avatar
Zrt1200
https://www.ford-trucks.com/forums/9...ds-update.html
Read this thread and follow the links, and do a search there.
​​​​​​https://www.460ford.com/threads/what...-build.233490/
Do a search here as well
​​​​​​https://www.ford-trucks.com/forums/forum53/
Nonowner
Nov 30, 2017 01:08 AM
T_Cooksey88
Jun 3, 2016 09:42 PM
7mpg302
Nov 30, 2008 06:49 AM
f10074
Jul 11, 2001 03:17 AM
rondog
May 15, 2001 01:27 AM
