1997 F-350 460 Towing Mods Update
I recently completed a cam change, etc. on my truck and wanted to thank Scott Johnston AKA “The Mad Porter” at RHP for all of his help. He dialed in my combo and his customer service skills exceeded my expectations. A custom cam from him wasn’t much more than an off the shelf grind and Scott answered every “newb” question that I had every step of the way. His answers were encouraging and helpful and were NEVER condescending. <o>
</o> My truck is a 1997 F-350 Crew Cab - Long Bed - 460 CA model w/ mass air - E4OD - 4x4 w/ 4.10 gears and 33 x 12.50 tires. It is mostly used for towing a 10k pound fifth wheel toyhauler from sea level, over a 4k’ mountain pass and back again. The engine/truck has 100k miles on it and my goals were to increase the torque without having to remove the heads and to keep it CA smog legal.<o>
</o> Mods to date (no cylinder head work/chip):<o>
</o> John Wood built E4OD<o>
</o> Banks headers and big single exhaust (previous mod)<o>
</o> K&N air filter in stock air box (previous mod)<o>
</o> Cut air horns (previous mod)<o>
</o> BBK 61mm throttle body (previous mod)<o>
</o> Ported intake manifold by RHP<o>
</o> Kirban adjustable fuel pressure regulator at 44psi WOT (46psi w/ vacuum unplugged)<o>
</o> Custom Voodoo 61600 cam with 114 LSA by RHP<o></o>
12 degrees initial timing<o>
</o> I drove the truck a few hundred miles to make sure that it was solid and then had the truck dyno'd at 229 HP/331 TQ at the rear wheels. Not bad for a smog legal engine with 100K miles on it and 33" tires, etc. that was rated by Ford at 245 HP/400 TQ at the flywheel. <o>
</o> I recently had my truck smogged and was pleased with how easily it passed CA’s strict emission requirements. CA does not check timing for my year, so I did not have to adjust that, nor did I adjust the fuel pressure regulator back to stock psi. <o>
</o> The truck has been running great (under 3k miles since completion) and getting 11.5 mpg highway and about 7 mpg highway towing 10k+ lb fifth wheel! (before mods was 10.5 - 11 mpg highway and 5 mpg towing…) The real test for me was pulling mountain grades (up to 6%.) Before the cam, etc. change, 35 MPH was the norm (with Banks headers, etc.) My truck/trailer combo will now pull the same grades at 45+ MPH (cruising speed-not floored.) <o>
</o> Am I happy with the results? Yes, very, considering the upgrades were mild and my expectations were realistic. I am the original owner of my truck and I wanted to stretch out its use for a few more years. In some ways, I wish that I would have purchased the diesel engine over the 460, but for my limited use it did not make sense. Maybe a built stroker engine in the future?<o>
</o> I am often amazed how people glean information from the pros on the forums and then turn around and purchase the recommended parts from someone else. You may or may not be able to purchase your parts cheaper from Summit or some guy on eBay, but they are not going to be there for you when you need help and have questions. For me, that pro was Scott Johnston at RHP, phone 253-988-6648, http://reincarnation-automotive.com.<o>
</o>
<o>></o>>
<!--[if !supportLineBreakNewLine]-->
<!--[endif]--><o>Dez</o><o>
</o>
- Advertised Duration (Int/Exh): 250/256<o></o>
- Duration @ .050 (Int/Exh): 207/213<o></o>
- Gross Valve Lift (Int/Exh): .503/.535<o></o>
- RPM Range: idle-5000<o></o>
</o>
<o>></o>>
</o>
I recently completed a cam change, etc. on my truck and wanted to thank Scott Johnston AKA “The Mad Porter” at RHP for all of his help. He dialed in my combo and his customer service skills exceeded my expectations. A custom cam from him wasn’t much more than an off the shelf grind and Scott answered every “newb” question that I had every step of the way. His answers were encouraging and helpful and were NEVER condescending. <O>
</O>My truck is a 1997 F-350 Crew Cab - Long Bed - 460 CA model w/ mass air - E4OD - 4x4 w/ 4.10 gears and 33 x 12.50 tires. It is mostly used for towing a 10k pound fifth wheel toyhauler from sea level, over a 4k’ mountain pass and back again. The engine/truck has 100k miles on it and my goals were to increase the torque without having to remove the heads and to keep it CA smog legal.<O>
</O>Mods to date (no cylinder head work/chip):<O>
</O>John Wood built E4OD<O>
</O>Banks headers and big single exhaust (previous mod)<O>
</O>K&N air filter in stock air box (previous mod)<O>
</O>Cut air horns (previous mod)<O>
</O>BBK 61mm throttle body (previous mod)<O>
</O>Ported intake manifold by RHP<O>
</O>Kirban adjustable fuel pressure regulator at 44psi WOT (46psi w/ vacuum unplugged)<O>
</O>Custom Voodoo 61600 cam with 114 LSA by RHP<O></O>
12 degrees initial timing<O>
</O>I drove the truck a few hundred miles to make sure that it was solid and then had the truck dyno'd at 229 HP/331 TQ at the rear wheels. Not bad for a smog legal engine with 100K miles on it and 33" tires, etc. that was rated by Ford at 245 HP/400 TQ at the flywheel. <O>
</O>I recently had my truck smogged and was pleased with how easily it passed CA’s strict emission requirements. CA does not check timing for my year, so I did not have to adjust that, nor did I adjust the fuel pressure regulator back to stock psi. <O>
</O>The truck has been running great (under 3k miles since completion) and getting 11.5 mpg highway and about 7 mpg highway towing 10k+ lb fifth wheel! (before mods was 10.5 - 11 mpg highway and 5 mpg towing…) The real test for me was pulling mountain grades (up to 6%.) Before the cam, etc. change, 35 MPH was the norm (with Banks headers, etc.) My truck/trailer combo will now pull the same grades at 45+ MPH (cruising speed-not floored.) <O>
</O>Am I happy with the results? Yes, very, considering the upgrades were mild and my expectations were realistic. I am the original owner of my truck and I wanted to stretch out its use for a few more years. In some ways, I wish that I would have purchased the diesel engine over the 460, but for my limited use it did not make sense. Maybe a built stroker engine in the future?<O>
</O>I am often amazed how people glean information from the pros on the forums and then turn around and purchase the recommended parts from someone else. You may or may not be able to purchase your parts cheaper from Summit or some guy on eBay, but they are not going to be there for you when you need help and have questions. For me, that pro was Scott Johnston at RHP, phone 253-988-6648, http://reincarnation-automotive.com.<O>
</O>
<O>></O>>
<!--[endif]--><O>Dez</O><O>
</O>
- Advertised Duration (Int/Exh): 250/256<O></O>
- Duration @ .050 (Int/Exh): 207/213<O></O>
- Gross Valve Lift (Int/Exh): .503/.535<O></O>
- RPM Range: idle-5000<O></O>
</O>
<O>></O>>
</O>
Thanks
BigLar
Dez
Looking forward to a complete report on your improvements, RacerGuy...
Thanks for the info. I've got a pile of parts waiting for install, but finding the time has been tough. It's great to hear that I'm on the right track being that I have really similar parts to your build. I'll have to grab an adjustable FPR after hearing how your truck ran. And I keep looking at the spare intake manifold I've got thinking it needs some RHP porting...
Papawheelie
30
02-23-2017 05:14 AM
Greg M-47
02-17-2012 02:19 PM
bismic
05-30-2011 10:06 PM
parkland
72
11-08-2008 06:56 PM
