DTC P0670
Old Apr 26, 2021 | 03:39 PM
JaxJim's Avatar
JaxJim
DTC P0670
A few weeks ago after checking for codes, using FORScan Lite, I had the following codes; P0671,3,5, and 7. Those have gone away and seems to have been replaced with P0670. Has the GPCM failed completely? Thanks for any guidance!
Old Apr 27, 2021 | 06:36 AM
Yahiko's Avatar
Yahiko
One easy way to check is to ohm each plug and wire to see if you have a good resistance in each one.
Old Apr 27, 2021 | 07:26 AM
JaxJim's Avatar
JaxJim
I will have to see if I can find a video on those tests.
Thank You for the reply. I'll post my results.
Old Apr 27, 2021 | 12:18 PM
JaxJim's Avatar
JaxJim
I found a ton and a half of video's on YouTube about this but also found a VERY informative thread on Powerstroke.org that included a copy of shop procedures on how to test everything dealing with the GP's. Showed socket and pin identifications and step-by-step testing details. The thread was started by ynpmoose on Feb 7, 2014 and is titled 6.0 Glowplug Control Module testing. If you have any DTC's related to glow plugs check it out. (unfortunately my issue is a short between the PCM and the GPCM)
Old Apr 27, 2021 | 01:03 PM
xcrsp440's Avatar
xcrsp440
Diesel tech Ron has a great video on testing glow plugs on the 6.0
Old Apr 27, 2021 | 11:45 PM
Yahiko's Avatar
Yahiko
Let me know if you need me to dig up the diagrams and I can post them for you after work.
Old Apr 28, 2021 | 09:56 AM
JaxJim's Avatar
JaxJim
I've got one for a 6.0 that shows pins and wire colors that should be enough. I appreciate the offer.
Old Apr 28, 2021 | 01:39 PM
Yahiko's Avatar
Yahiko
Looks like you have it covered.
Bebopjop
6.2L V8
Oct 17, 2020 12:49 PM
Simon6.0F350
Oct 2, 2020 07:51 PM
iateatoad
13
Dec 8, 2012 10:35 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
