Sponsored by: Auxito
HVAC Diagnostic Checklist
Old Apr 26, 2021 | 07:03 AM
MZX's Avatar
MZX
I am looking for a diagnostic checklist that I can step through to fix my HVAC system. There may be something on here, but I was unable to find one.
HEAT:
Temperature gauge operates as it should. When heat is turned on, the cabin only warms up what feels like 1 degree warmer than outside.
A/C:
Topped off the Freon and compressor kicking on and off as it should. A/C in cabin is only cooling what seems to be 1 degree below outside temp.
With the key in the on position but the vehicle is off, spinning the temperature **** from cold to hot and from hot to cold, I hear movement in the climate control, so I believe the actuator is working.
They may be two sperate issues or they may be the same issue. I do not know.
I appreciate any assistance.
Thanks
Old Apr 26, 2021 | 10:39 PM
steve(ill)'s Avatar
steve(ill)
if you have no heat and no AC... i would look at the control **** slipping on the shaft, or the BLEND DOOR flopping around inside the duct.. You would still hear the actuator working.
Old Apr 27, 2021 | 06:34 AM
projectSHO89's Avatar
projectSHO89
It helps if you identify EXACTLY what you are working on, including which HVAC system is involved.....
Old Apr 27, 2021 | 06:57 AM
MZX's Avatar
MZX
My apologize. It is a 1998 F150 XL with the 4.6 and manual everything.
Old Apr 27, 2021 | 08:34 AM
steve(ill)'s Avatar
steve(ill)
Old Apr 27, 2021 | 08:38 AM
steve(ill)'s Avatar
steve(ill)
Old Apr 27, 2021 | 11:29 AM
projectSHO89
Could be anything from the stripped **** already mentioned to a faulty temperature control to a jammed blend door to a failed blend door actuator. Of course, it could also be two problems. One would be no hot coolant circulating through the heater core, the other would be the refrigeration system isn't working. Suggest checking the temperature of the pertinent lines/hoses so you know which side of the firewall to focus your efforts on. Failure to do so often results in wasted time and money chasing the wrong thing(s).
Check out the HVAC FAQS, link is in my signature. Most of this stuff was covered over a decade ago when I wrote those.
Old Apr 27, 2021 | 11:31 AM
MZX's Avatar
MZX
Thank you everyone for your input. It is very helpful.
Old Apr 27, 2021 | 11:51 AM
projectSHO89
I updated my previous post so go back and check it again...
joel3303
6.4L Power Stroke Diesel
Oct 21, 2019 10:40 AM
97ExpGuy
Jun 24, 2014 07:01 PM
cam_12484
2004 - 2008 F150
Dec 8, 2009 07:46 PM
KHaga
May 23, 2008 09:25 PM
amsrus
1997 - 2003 F150
Oct 30, 2006 08:42 PM
