Sponsored by: Auxito
Fuel Door Problem
Old Apr 25, 2021 | 07:39 AM
Larryjr03's Avatar
Larryjr03
Fuel Door Problem
2003 F150. Recently had a red light start to flash , lower left of instrument panel, Fuel Door . truck does'nt have a fuel door, just a
a lid that you pull open, so I thought must be the Fuel Cap, it looked like might have been on there since day one, so I ordered a genuine Motorcraft cap, installed that, still have that light coming on, flashing. What in the world ? Any help appreciated. Thank you. Final note, it states on new cap, and old one, turn until it clicks, with an arrow showing clockwise, but I don't ever hear that click until I take the cap OFF ????????
Old Apr 25, 2021 | 09:38 AM
steve(ill)'s Avatar
steve(ill)
from an old post... air is leaking into your tank, or the wires on the sensor are corroded... air can leak in thru the canister vent valve, or around the gas tank cap.
OLD POST----------, but the system also needs to have the cannister purge valve closed when it's performing that test. That's why a purge valve stuck in the open position can trigger that light. As far as the system knows, the most common source for that type of gross evap system leak would be a fuel cap someone forgot to replace after refueling. It still could be either the bad valve//solenoid or a bad fuel cap. I'd want the tech to explain to me why it's NOT the cap and why it IS the valve before I OK the replacement.
rob17
Nov 20, 2022 03:12 PM
CMOS
2009 - 2014 F150
Mar 6, 2016 08:06 PM
radium
6.7L Power Stroke Diesel
19
Jan 26, 2016 06:59 AM
Icthus in AK
89
Feb 21, 2015 08:59 AM
biggreentank
23
Oct 1, 2006 02:15 PM
