Sponsored by: Auxito
Heat
Old Apr 11, 2021 | 06:48 PM
bazzman1953's Avatar
bazzman1953
Question Heat
Heat is a nice thing to have have here in da "YouPee', the problem is that I have none. Background... '03 SuperCab. 170.xxx. Arizona truck so not a rust bucket. Back in late Oct last I went to park my 22' trailer at a friends place for the winter. Truck was idling as I hooked it up and showed normal temp. Drove it 1/2 Mi and had to pull over and shut it off as the temp was pegging on hot. Fired it up a coupla min later and the temp started dropping down to normal and has been there since. Fast forward to this year in Feb. suddenly no heat. Added more coolant than I expected to and had heat again. Yesterday when our temps dropped suddenly no heat. Engine temp was normal and I've topped the bottle up 2x today without luck. Thermostat?
Old Apr 11, 2021 | 09:43 PM
Lime1GT's Avatar
Lime1GT
You might want to change your thermostat when you repair your coolant or head gasket issue.
Old Apr 12, 2021 | 09:21 AM
steve(ill)'s Avatar
steve(ill)
i had a minor head gasket / etc.. leak.. Would use a small amount of antifreeze over a month until NO HEAT... Then you had to top the radiator off again... I ended up putting a bottle of BARS COOPER HEAD GASKET SEALER into the motor ( 2001 F150 ) and that seemed to seal everything up. Really didnt want to get into a HEAD PULLING program with an older truck.... Pull the top radiator hose and pour the 16 oz bottle into the hose ... dont add to the overflow tank.
Old Apr 24, 2021 | 01:49 PM
bazzman1953
It turns out that the blend door activator had failed. Had it fixed and now I have heat again
Old Apr 25, 2021 | 09:27 AM
steve(ill)'s Avatar
steve(ill)
????? so where did the antifreeze go ??
Old Apr 25, 2021 | 10:01 AM
Lime1GT's Avatar
Lime1GT
exactly. hvac may work for now but cooling system still has issues.
scottswierenga
Dec 7, 2013 07:08 PM
Ridenred333
Modular V10 (6.8l)
53
Mar 30, 2013 06:08 PM
handsomerob
17
Jan 20, 2008 09:23 PM
JamesT96GT
1983 - 2012 Ranger & B-Series
13
Sep 3, 2005 01:08 PM
97flairside
24
Feb 11, 2005 07:11 AM
