08 SX2 first and reverse only
I just picked up this FX2 at an auction. I've looked around and used the search but didn't find an answer. It's got the cam phaser problem but I already know the remedy for that. The issue I need help with is the transmission. First gear and reverse work but second and drive are none existent. I drove it home from the auction in first gear. I also checked the fluid level and topped it up. Is this a shift solenoid problem? I haven't come to the dark side before so this is my first Ford since the 80's. I like the truck but I need to know what the problem could be. Do these have shift solenoids and what else could cause the no gears after first? 5.4 Triton automatic.
Thanks for any advise you may have other than sell it to me for parts
