wont move forward unless its put in reverse first
Old Jan 31, 2015 | 10:38 AM
Walwal44's Avatar
Walwal44
so yesterday I went out to my 1996 f250 7.3 and I went to leave and the rpms went up but the truck didn't move. I thought I accidently put it into neutral but it was in drive. I put it in reverse and backed it up it made a loud bang then I out it back in drive and I was able to go. it also did the same thing this morning. could it just be the fact its been in the single digits the past few days or do I got a problem?
Old Jan 31, 2015 | 03:24 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
sounds like the MLPS may be suspect Wally.careful because the BANG as it finds a gear again isn't any good for it.
your connection may be getting dirty from road slush.pull it off and have a look to see if it's still sealed up.
large sensor located on the drivers side,behind the shift linkage.if you can't get to this for a bit,but still need to truck,use caution.be prepared for the trans to go into N on you going down the road.quickly shift into N and roll to a stop so you don't get the BANG back into gear,shift back to D once fully stopped and take off easy again (may or may not engage promptly.baby it.)
lets go pats!
Old Feb 2, 2015 | 05:12 AM
TexasGuy001's Avatar
TexasGuy001
I would suspect the MLPS or just low fluid level.
JR58
6.4L Power Stroke Diesel
Sep 7, 2015 04:34 PM
JaySVX
Nov 1, 2014 11:41 AM
asok
Oct 14, 2009 02:53 PM
farmb0y
Mar 12, 2008 01:05 PM
flash95
Sep 16, 2003 07:44 PM
