Trans issues
Old Dec 17, 2008 | 11:26 PM
randomhero1172's Avatar
randomhero1172
Trans issues
3 speed trans, infos in sig
Was doing 2900 rpms on the freeway today (58mph or so) and all of a sudden 3rd gear sounded like it gave out and the truck shot into second. the engine redlined but i slowed down before any damage. I dont think the trans blew but am no expert on the trans. It wouldnt shift back into 3rd but was fine in 1st and second. Temp was just fine on engine and tranny. I just got the damn thing running too (new starter, alternator,voltage regulator, re wired, etc) Whats your thoughts? what would be the first place to look? Thanks - Joe
Old Dec 17, 2008 | 11:41 PM
joe f350's Avatar
joe f350
well joe form one joe to anthor dose ur shifter have a
3rd gear on ther gear sector besides drive
Old Dec 18, 2008 | 12:01 AM
randomhero1172
Hmm....just from memory recall i think it does
Old Dec 18, 2008 | 12:05 AM
joe f350's Avatar
joe f350
try that and if that fails is it an eod40 it might be in limp does ur tack work this is y i have a t19
Old Dec 18, 2008 | 12:22 AM
randomhero1172
Its an x u-haul. I have already counted the bolts and confirmed a c6. some said its kinda rare to have a 90' with a c6 but u haul used it in trying to limit speed on these vehicles. Im thinking somethings wrong with vacuum? wheres the vacuum unit located? Is there any way to test for leaks? can i run smoke through the lines to try and pinpoint a leak? Which line would cause 3rd gear to just give out? Hmmm - thanks for the input so far. Ill try the 3rd gear manually tomorrow (this actually puts it in third? sorry stupid question! lol)
everything is working fine, tach,gauges, and it never had a problem.
Old Dec 18, 2008 | 12:29 AM
joe f350's Avatar
joe f350
let me think x u haul how many miles on the truck it could be a really bad tranny slip did u check the fluid
Old Dec 18, 2008 | 12:35 AM
randomhero1172
Fluid is great. nice and red.Doesnt look or smellburnt. miles in sig ... This just doesnt seem like a internal trans issue. Seems like it lost vacuum and slipped outta gear, the vacuum isnt there to throw it back into 3rd now. Maybe v pump lost some power and can only run 1,2 . Dont kno much about the vacuum system
Old Dec 18, 2008 | 12:39 AM
joe f350's Avatar
joe f350
what dose the the vacumm run off where is the pump located what dose it run off belt or is it intural
Old Dec 18, 2008 | 12:40 AM
rupejosh's Avatar
rupejosh
if its slipping i know what you could put in it.can ya guess joef350?lol
Old Dec 18, 2008 | 12:42 AM
joe f350's Avatar
joe f350
lucas oil u have an love affair with lucas products
Old Dec 18, 2008 | 12:58 AM
randomhero1172
Worth a shot! Ill pick some up tomorrow. From doing some research, vacuum runs on belt. Has common issues with vacuum lines rubbing and going bad.
Old Dec 18, 2008 | 01:00 AM
joe f350's Avatar
joe f350
bult or belt the belt could be sliping
Old Dec 18, 2008 | 01:05 AM
randomhero1172
Ill check it out tomorrow and come back with some better info. Thanks for everything so far
Old Dec 18, 2008 | 01:13 AM
joe f350's Avatar
joe f350
i try my best to help this site has saved me thousend in labors and buying the right parts
Old Dec 18, 2008 | 01:16 AM
David85's Avatar
David85
That would be the first thing I would check. Alternator and vacuum pump belts.
What are your power brakes doing? are they affected at all?
