A/C pulley loose
Old Apr 20, 2021 | 08:47 AM
The other Joe's Avatar
The other Joe
A/C pulley loose
Hi all,
I just noticed a slight squeaking noise when the a/c is on. I removed the belt to check all the pulleys and found I can move the a/c pulley very slightly front to back.
My question is. Can I just replace the clutch assembly? Or do I need to replace the compressor?
The a/c is cooling fine.
thanks,
Joe
Old Apr 20, 2021 | 09:34 AM
thor363's Avatar
thor363
Here ya go.
https://www.ford-trucks.com/forums/1...lutch-gap.html
Old Apr 20, 2021 | 09:51 AM
The other Joe
Originally Posted by thor363
Thanks Thor.
I will pick up a new clutch and pulley.
Thanks
Joe
Old Apr 20, 2021 | 10:27 AM
thor363's Avatar
thor363
Sure you need one? What's the clearance?
Only thing that squeeks on mine if the idler, so I replaced it. Also, pretty sure I have 2 spare belts so I know the prior owner hadn't figured that one out.
Old Apr 20, 2021 | 10:58 AM
The other Joe
Thor,
I do believe the pulley bearing is the main problem because the pulley itself has free play.
I checked my other f250 and that pulley has zero movement front to back.
And all the other bearings are nice and smooth and tight.
I didn’t measure the gap. But I did replace the clutch a couple years ago and set the gap at that time.
My plan is to get a bearing or a pulley with new bearing.
Then I will disassemble and see for sure.
question. If the clutch itself was bad, how would that cause the pulley to be loose?
Am I missing something?
thanks,
Joe
Old Apr 20, 2021 | 12:41 PM
thor363's Avatar
thor363
Didn't realize you found that 'slop' in the bearing, agreed time for new.
If you're pulling the system down at all, check the price of a new unit. Mine for the Cummins conversion was unmistakenly cheap and quite nice.
See, we are good at spending your money!
Old Apr 20, 2021 | 05:08 PM
The other Joe
Im doing everything I can to not open that can of worms.
I just ordered a bearing.
I can get a new compressor for less than $200. But then the dominoes start falling with the age and mileage on this Ex.
new dryer, orifice tube, condenser, etc.
The V10 still runs good, but has 233k.
thanks,
Joe
Old Apr 20, 2021 | 06:07 PM
01__Excursion's Avatar
01__Excursion
Ugh, I just went through all of that, from leaking front compressor seal to everything I could get my hands on. A proper deep vacuum brought out and created a few leaks in other places. Ended up buying all the clutch pulley tools too that I'll probably never use again....
https://www.ford-trucks.com/forums/1...l#post19149045
Old Apr 20, 2021 | 06:27 PM
The other Joe
[QUOTE=01__Excursion;19842354]Ugh, I just went through all of that, from leaking front compressor seal to everything I could get my hands on. A proper deep vacuum brought out and created a few leaks in other places. Ended up buying all the clutch pulley tools too that I'll probably never use again....
I just looked at your link. That is exactly what I don’t want to do. At least your compressor is on top. The V10 is in the lower right corner. Not much room.
Your level of detail is fantastic. Nice Ex.
thanks,
Joe
Old Apr 20, 2021 | 06:32 PM
01__Excursion
[QUOTE=The other Joe;19842372]
thanks,
Joe
Sorry I didn't catch the V10, I should know I briefly had one for year that I just sold last November, it received a few of the parts from the 7.3. I thought what a bi--h to get to the V10 compressor.
Take the inner fender liner out for sure.
Old Apr 20, 2021 | 06:52 PM
The other Joe
[QUOTE=01__Excursion;19842382]
From everything I have seen the inner fender needs to be moved or removed to replace the compressor.
I have been able to work on the front clutch piece without doing that. I hope I can get the pulley off the same way.
I also have a 7.3 in a 97 f250. The compressor couldn’t be in a better place.
The V10 has been pretty good. But I wish I had the 7.3
Old Apr 20, 2021 | 07:06 PM
01__Excursion
One day I will no longer find mine practice, and it too will find another owner....
Old May 2, 2021 | 08:14 AM
The other Joe
Just a follow up on the loose a/c clutch pulley bearing.
I was able to remove the pulley and replace the bearing without any other disassembly.
Not much room to work. But I got it.
thanks again,
Joe W
1956lando
Jan 12, 2013 11:45 AM
keninshiloh
1997 - 2003 F150
Sep 6, 2011 06:15 AM
03_PSD
22
Mar 1, 2010 10:02 AM
tractoman
Jun 22, 2006 12:29 PM
tommyleea
General Automotive Discussion
Jul 4, 2004 04:34 PM
