Hyper-blink turn signal problem, please help
Old Apr 19, 2021 | 04:46 PM
Mack3006's Avatar
Mack3006
17’ f250 6.2 XLT
If I use my right turn signal it will hyper blink(on my dash), showing me a light is out.
Only right side blinker.
I check both of my turn signal bulbs, front and back, cleaned and dielectric grease. No visual problems and both blink with out a issue at standard blinking speed.
anyone else experience this or have a fix? Or any other places I should check. It’s super annoying while driving
Thanks in advance.
Old Apr 19, 2021 | 08:59 PM
Rich53's Avatar
Rich53
Ther ware lots of posts about issues with water getting into the electrical connectors in the rear either side of the spare tire and above it. They need to be pulled apart, make sure there is no corrosion and filled with dielectric grease. Water in these has resulted in all sorts of weird electrical gremlins.
Old Apr 20, 2021 | 05:07 AM
B-ManFX4's Avatar
B-ManFX4
Any chance you changed the bulbs to LED bulbs ?
Old Apr 20, 2021 | 09:35 AM
Mack3006's Avatar
Mack3006
No, standard marker and blinker bulbs.
mail headlights are LED bulbs but the have been in for 3 years without any issues.
Old Apr 20, 2021 | 11:22 AM
Glen Kierstead's Avatar
Glen Kierstead
I had this problem when I bought my 17 back in August. Both sides did it. Well finally I realized just YESTERDAY that the bulbs 3157 have two filaments in them. One for the brake light/running tail lights and the other for the turn signal. Low and behold the filament for the turn signals was out but not the filament for the brake lights/daytime tail lights. Bought two new ones for $8 and problem solved! It drove me nuts for almost 8mo haha!!! Good luck and I hope this fixes your issue.
Edit* Both top and bottom bulbs blink for turn signal low and behold it was both of my bottom ones having that issue. I didn't realized both bulbs were used for turn signal that's what took me so long to figure it out cause they both looked the same.
Old Apr 20, 2021 | 04:26 PM
Mack3006's Avatar
Mack3006
awesome find!!!
I will do this ASAP.
thanks for the help
Old Apr 20, 2021 | 09:24 PM
Mack3006's Avatar
Mack3006
So I found the problem. Double element in one of the lower back bulbs.
it looked perfect intact with no discoloration, but did not light up.
thanks for the help
Old Apr 20, 2021 | 10:20 PM
Glen Kierstead
thanks for the help
Outstanding! Glad I could pass this along. It drove me nuts with the hyper flash. Lol
Old Sep 11, 2024 | 02:28 PM
Turn_em's Avatar
Turn_em
3rd Gear
Fast blinking turn signal
I have a 2015 Ford F250 . I too have the blinker problem. The front left parking light does not come on. The blinker on the left front blinks normal when the headlights are not on. Turning the headlights on , I have a rapid blinking. I did change the left turn signal bulb...to no avail. The left parking light still did not come on. So I'm thinking there is moisture in the rear tail light connectors like Rich53 mentioned. So, called Ford dealer. He said if that's what it is, it will be 2,000.00 bucks to fix..!!!! OMG What a rip off. Lucky for me I have the extended warranty. So we will see. I will repost to let you all know what the outcome is.
Mike in Ohio
Nov 12, 2010 12:09 PM
afonda
22
Dec 20, 2008 01:47 PM
SPreston2001
Aug 28, 2008 01:26 AM
kdl
1997 - 2003 F150
Sep 13, 2004 10:55 AM
1BigExpy
Feb 28, 2004 02:59 PM
