Sponsored by: Auxito
fast flash turn signal indicator
Old Sep 10, 2004 | 08:56 AM
kdl's Avatar
kdl
I have a 2003 F150 Super Crew. The left turn indicator has started flashing real fast. I think this is probably just a turn indicator fuse or something, but not sure where to locate it so I can replace it. ?????
Old Sep 10, 2004 | 09:28 AM
DonsFx4's Avatar
DonsFx4
Usually it's caused by one of the turn signal lamps being burnt out. Check 'em all and see. If not, the turn signal modules probably bad.
Also, check a couple of posts down on this board "turn signal problem".
Good luck!
Old Sep 13, 2004 | 10:55 AM
kdl's Avatar
kdl
Thanks- I replaced the rear bulbs this weekend-problems solved.
