usually it's a bulb out. Occasionally it's your flasher unit going bad. Every vehicle I've ever owned would do something weird with a bulb out. Imports just stay on solid when a turn signal light goes out, instead of flashing faster........
Like Travis said also. I have seen, on rare occasions, the flasher cause only one side not to work correctly. I work on alot of OTR trucks and trailers and have seen many different wiring and light problems.
Bad bulb, 100%. Mine did the same thing. 2 pack of them cost like 4 bucks at Wal-mart if i remember correctly.
I always keep spares in my truck and garage. I have a pretty good selection of fuses also. I don't like to run 20 miles to town for a couple o' bucks part.
If that doesn't work try pushing down the hazard button on and off. My truck's left turn signal would just start flashing for no reason. The only way to shut it off was to turn on the hazards then turn them off.
Good point, and i,m ahead of yaa on that one Roland, . purchased the pack of two and 9 months later the other one goes. Grabbed another pack plus some other ones and got them and the fuses in the glove along with my emergency candy bar.
