DEAD HPOP
Old Apr 18, 2021 | 02:05 PM
Simon Espinola's Avatar
Simon Espinola
Angry DEAD HPOP
Good afternoon,
Well Ladies and Gentleman... My HPOP is DEAD
When i do the air test, there's air coming from the lubrication lines
I put a tiny shim between the HPOP and the J tube to close it from the HPOP, then, i applied pressure installing a hose in the tip of the J tube to the HPOP head
After 30 minutes, the hose blew away, wich meansthat my lines are NICE, still I will replace my STC o-ring
I found the cheapest on ebay: Remanufactured by Pensacola Diesel, the reviews are positive
Someone bought a 6.0 HPOP from those guys???
Old Apr 19, 2021 | 01:38 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Avoid Ebay for critical parts.
When you see the word cheep keep in mine it most likely is junk.
Old Apr 19, 2021 | 03:23 PM
Visurveyor's Avatar
Visurveyor
Ficm repair.com or XDP Diesel
Good services, prices and warranties.
Old Apr 20, 2021 | 07:47 AM
Simon Espinola
Bro, I WON'T pay a LOT of money
Keeping a budget
There is no cheap
Old Apr 20, 2021 | 07:54 AM
Simon Espinola
Daaaaaaang bro
720 bucks for a HPOP
Forget it
Old Apr 20, 2021 | 09:48 AM
TooManyToys.'s Avatar
TooManyToys.
You need a different vehicle.
Old Apr 20, 2021 | 11:40 AM
Simon Espinola
What you mean???
The prices???
Well if there's something cheaper and it is the same thing... Well
Old Apr 20, 2021 | 11:12 PM
Yahiko's Avatar
Yahiko
FTE Remembers
There have been more stories of people going cheep and then
getting stuck having to buy the sane part all over again and
then do the work again.
Old Apr 21, 2021 | 03:37 PM
Visurveyor's Avatar
Visurveyor
Simon a cheaply rebuilt Hpop looks and works the same as a quality built on. Buying from a reliable shop or buessines will get you better quality rebuild, better parts and a warranty.
Old Apr 21, 2021 | 03:38 PM
Visurveyor's Avatar
Visurveyor
Oops resend.
Old Apr 21, 2021 | 04:58 PM
bismic's Avatar
bismic
Good luck with this discussion. There simply is SOMEWHAT LIMITED data (and certainly no absolute proof) either way.....
There are technical articles on the design issues that the early OEM pumps have, and several companies selling modified ones list examples of OEM design issues (DieselSite and CNCFab). A person either values that information, or considers it "propaganda" of sorts.......
Old Apr 22, 2021 | 03:40 PM
Byrd.Dog's Avatar
Byrd.Dog
There have been lots of documented issues with rebuilt HPOP's failing right out of the box, even ones purchased through the dealership. Aftermarket seems the way to go on this one, but I have no personal experience in that dept.
Old Apr 22, 2021 | 03:57 PM
bismic's Avatar
bismic
I agree, but some argue that the failures out of the box were due to a lack of priming the HPO system before cranking. I have a hard time with that concept, but just saying the detailed "forensic" work has not been done.
If I had an early OEM HPOP, I would replace it with one that had been "improved" by a quality/reputable aftermarket company (no surprises there for anyone I am sure).
Old Apr 22, 2021 | 06:30 PM
Simon Espinola
I don't wanna pay from 850 to 1600 bucks for a performance hpop, STOCK
Old Apr 22, 2021 | 06:35 PM
bismic's Avatar
bismic
No one is suggesting a performance (higher output) HPOP - just a reliable STOCK rated one. I think you might be just hearing what you want to hear.
