Hyper Flash
Old Apr 13, 2021 | 02:42 PM
Fire Two's Avatar
Fire Two
Hyper Flash
I had a Bradford flatbed installed that has LED lights, which caused my turn signal to hyper flash inside the cab but the exterior lights function normally. Adding resistors to the lights didn't help. I have seen where programing changes to the body control module can correct the problem. So, my question is, does anyone know of a Forscan tech in the Carson City, NV area that can make the required changes I need? Many thanks.
Old Apr 13, 2021 | 05:11 PM
94yj's Avatar
94yj
have you had the one that installed the bed check it they may have a way to program the circuit to get rid of the hyper flash
Old Apr 13, 2021 | 09:25 PM
Fire Two's Avatar
Fire Two
The installer tried resistors with no success. They did not have a program that would effect the hyper flash. From what I have read the only remedy is to use Forscan to change a few settings. By the way, this is a 2017 F-350.
Old Apr 13, 2021 | 11:28 PM
NV Guy's Avatar
NV Guy
I believe the Dealer can change that. Service bulletin Q-261R1
Ford Body Builder
Old Apr 14, 2021 | 09:30 AM
Fire Two's Avatar
Fire Two
Thank you NV Guy. I spoke to one guy at a dealer, he wasn't familiar with the issue. I'll get back to them and refer to this bulletin number. Thanks again.
troverman
2017 Ford SVT F150 Raptor
Sep 13, 2017 10:09 AM
uknunn
Aug 6, 2017 01:09 PM
Leathers65
Jul 17, 2017 10:49 AM
rcw3023
1983 - 2012 Ranger & B-Series
Jan 10, 2017 10:54 PM
rescue947
15
Mar 16, 2013 06:34 AM
