55 F100 coyote build
Hi I am new here but have been looking for good info on F100 builds for a while now. I decided to start building my F100 up this winter, I shoved a 34 Ford coupe into the barn so I could tackle this project.
after year down and blasting a mustang 2 front end was installed with ridetech airbags, a shortened spooled 9 inch with 31 inch slicks in the rear (slicks are going to be smaller when done) ridetech 4 link in the rear. Power plant I finally decided on a 5.0 coyote the other day, picked that up and 6r80 to go with it. I just started mocking that up yesterday.
I had been reading through some of the other thread that was super good on the 53 aluminator but his thread just died so I hope some
of those people can help give me some advice on finishing mine up.
My biggest problem now is the motor with fat fender mounts is going to have steering clearance issues. Down below I have a photo of that.
The day I decided to pull the F100 out of the field. I pushed a 34 Ford coupe aside to start this truck, I thought it would be a faster build but then I decided to get crazy on it.
Getting ready to lift the cab
Stripping the frame for sand blasting
Mustang 2 front install
Welded closed the million holes Ford put in these frames
Rear end mocked up, love it when slicks fit with no modification
Boxing in the frame, before this the frame flexed so bad I would have twisted into a pretzel
Ridetech 4 link going in
Truck will be on airbags all the way around
I had no idea how much notch the frame would need, I later learned this was excessive
Bags installed on the front, she gets really low
Start of trying to mock up the motor. I have fat fender motor mounts to try this with.
Not sure i like how fat fender placed the mounts I’m definitely going to have clearance issues with steering
I purchased most of my parts from speedway. The M2 crossmember is the speedway crossmember. It’s very similar to heidts. I didn’t want to buy the complete kit because I knew I was going airbags so I wanted the ridetech lower a arms for airbags.
Have a technical motor mount question. Passenger side mount clears just fine the driver side impacts or gets way to close to the steering rack. Do motor mounts need to be as symmetrical as possible? If I flip the driver side mount I get plenty of room. Only problem is passenger side doesn’t flip.
Driver side when it matches the passenger side. This was before I had to move the motor even farther back where it actually touches now.
Driver side flipped upside down.
i thought about shortening it just didn’t feel like cutting it at that time may still try shortening it
Well I was waiting on a new oil pan to arrive to help with placement issues on the frame so I started working on the cab rust....
Can had more rust then I originally hoped. Guess I’m gonna learn sheet metal work today.
Formed an oval piece and welded shut the gas tank hole
Turned out ok for my first time ever playing with sheet metal
Not sure how I’m going to proceed with this yet
Found a lot more rust then I anticipated think I need a new rocker panel and this inner corner now
Decided to get crazy and shave the drip rail.
Hasn’t been too hard yet on the sides. I started with a air grinder but it took a while to cut through. Found that the sawsall fits perfect and cuts quick, just making sure I angle away from the cab.
Livin the same dream Stroker
Thanks for sharing your photos, looks like we're working on very similar projects. I have the gen 2 2016 F150 Coyote with a TR3650 5 speed in mine. Had the cab painted and installed it a couple of weeks ago and am slowing putting things back together. Thanks again for sharing, nice work!
Start a new thread and introduce yourself with lots of pics of your truck!
the stock frame is actually garbage on these trucks and flexed all over the place even with all those crossmembers. After boxing the frame with 3/16 plate I added a rear crossmember for the airbags. Between just the rear crossmember and the mustang 2 crossmember the frame doesn’t flex at all. I’m adding one more crossmember in the middle with a driveshaft loop once I have the driveshaft in.
If I was to redo this project I would have just built a new frame with 2x6 stock.
