Sponsored by: Real Truck
Removing the fender emblems.
Old Apr 11, 2021 | 03:02 PM
Hotcross's Avatar
Hotcross
What's the best way to get the fender emblems off without hurting the paint? I have some stick on decals to replace whats on there now. Thanks for the info.
Old Apr 11, 2021 | 05:07 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Heat gun on low and keep moving over the emblem, warm it.up slightly and then use fishing string between the emblem and body.
on my 2004 I used the heat gun and a set of plastic body tools from harbor freight, I used three pieces of blue painter's tape around the emblem and carefully got the corner up then grabbed it with my fingers and pulled the emblems right off
Then the left over double sided tape I used microfiber cloth and citrus label remover fluid.
Old Apr 11, 2021 | 06:09 PM
Hotcross's Avatar
Hotcross
What's the purpose of the holes in the fenders? I thought they were held on by some type of fastener.
Old Apr 14, 2021 | 01:56 AM
marksman76's Avatar
marksman76
The purpose of the holes is because FORD is smart, and force you to leave on the emblems.
In reality the holes make for quick alignment on the assembly line would be my guess.
SuperDutyScaler, what did you do to cover up the holes??
Old Apr 15, 2021 | 06:55 PM
Hotcross's Avatar
Hotcross
The fishing line worked great! I used 12lb test , I think 15 and up would be better. It was 40° with an old hair dryer and 90% alcohol . Thanks for The tip.
Flooringit
Sep 4, 2017 07:38 AM
redbull660
Appearance & Dress-Up
Jan 17, 2012 05:31 PM
daveengelson
Paint & Bodywork
Aug 3, 2007 11:30 PM
trumpboy77
Paint & Bodywork
May 16, 2005 02:35 PM
66CustomCab
Mar 17, 2004 01:06 PM
