Sponsored by: Real Truck
Advancedtrac.... Please stop beeping... Help
Old Apr 7, 2021 | 04:46 PM
Vivere il Kairos's Avatar
Vivere il Kairos
2011 f250 XLT crew cab. I get the service advancedtrac check light and beeping constantly. If I turn it off, if I have it in four high or four low. When it tells me to service it will not turn off.
If off, it turns back on when it tells me to service it.. And don't forget the constant beeping...arggg
I've taken it in a couple times. It doesn't send a code unless it's currently beeping at me with the wrench on the display.
They one time It happened and the shop checked the code it stated;
3 faults
ABS-Abnormal.
U0001 high speed CAN communication bus-Continuous memory DTC's-.
APIM (Accessory-Abnormal.
Those are the 3 faults and the shop said they didn't know how to fix it and couldn't find a solution.
Anyone run into this problem and fix it?
At least, how do you disable that damn buzzer...? It goes on and on and on and on....
Thank you
bkuuz1
6.7L Power Stroke Diesel
72
Feb 21, 2023 10:37 PM
Fefanatic
Feb 13, 2019 08:07 PM
OBX Powerstroke
6.4L Power Stroke Diesel
33
Sep 10, 2015 04:05 AM
2002explorer
Modular V8 (4.6L, 5.4L)
16
Mar 17, 2005 10:37 PM
profarmen
Sep 9, 2004 09:23 PM
