6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DTC P0088
Old Jul 31, 2011 | 11:17 AM
OBX Powerstroke's Avatar
OBX Powerstroke
DTC P0088
Engine light came on and ran code scan, code P0088 came up indicating a high pressure fuel injection issue. 2008 with 75k miles. Did a little research and saw where a service bulletin has been issued. Cab off fix Anyone else have this code recently?
Old Jul 31, 2011 | 02:22 PM
senix's Avatar
senix
Could be a number of things Maybe VCV, low pressure system or the pump itself. Sounds like you maybe headed for a cab off.
Best to take it in for proper dianosis
Old Jul 31, 2011 | 02:41 PM
OBX Powerstroke
Thanks senix for your input, already have call service dept. on my to do list for tomorrow.
Old Aug 5, 2011 | 05:22 AM
senix's Avatar
senix
Any update on this?
Old Aug 5, 2011 | 05:57 AM
parkland's Avatar
parkland
Did you get loud injection events at all prior?
Anything different at all?
Old Aug 7, 2011 | 02:01 PM
OBX Powerstroke
Senix - No update yet, wound up getting a kidney stone and have not had truck to dealer yet, hope to get it in shop this coming week.
Parkland - I did hear some loud noise, sounded like a fan growling if that makes sense.
Old Aug 7, 2011 | 02:04 PM
senix's Avatar
senix
I had a kidney stone one time..not a fun adventure!
Old Aug 7, 2011 | 06:21 PM
Tom's Avatar
Tom
Well just to state the obvious:
P0088 = Fuel Rail/System Pressure - Too High
Both the PCV and VCV are integral parts of the HPFP; there is no servicing either one of them. I'm willing to be either one of these are your problem. Attached is an image of your HPFP and each of these valves...note the part where it says they can't be replaced.
Now I'm no tech, but from what I gather you need a new HPFP. With any luck the damage is confined to these valves and didn't end up munching up parts and sending them to your injectors. Good luck, and please let us know how it turns out!
Old Aug 7, 2011 | 07:09 PM
Jessef250's Avatar
Jessef250
When we get this code in the dealership, we check low fuel pressure to motor, pull secondary fuel filter inspect inside housing, and if metal shavings are found, we pull valve covers, inverse the front injector on either side, and see if metal contaminants are found. Get approval to pull cab, remove hpfp cover inspect cover harness and electrical plug-ins to pump, replace pump and necessary parts..
Old Aug 7, 2011 | 08:40 PM
bnmccoy's Avatar
bnmccoy
Jessef250, and what is the typical cause of this type of failure?
Is this where you are also looking for evidence of water contamination? or does that cause a different failure?
Just trying to understand.
Bob
Old Aug 8, 2011 | 07:40 AM
Texas450's Avatar
Texas450
I had this code at 90k miles and it was pull cab and replace hpfp time
Old Aug 8, 2011 | 07:54 PM
wp6529's Avatar
wp6529
An additional possibility would be a bad fuel pressure sensor.
Old Aug 8, 2011 | 08:15 PM
vloney's Avatar
vloney
Just to throw this out there, (show you how much diagnostics matter), I had one throwing the p0088 code. Looked at the tsb, and ordered a pump. Put it on, and a short time later, it was back with the same code. I took a long test drive with the IDS, and the cruise control quit. I talked to the owner and he admitted it would do that. Think about this one, when it would do it, it would also dim the lights (that was important). In the pcm connector, pin 39 is the FRP (fuel rail pressure) pin 16 (next to 39 but above it) is the generator (13.5 volts). They were shorting together internally when hitting a bump, setting FRP too high, and dimming the lights (13.5 volts going to 5).
Old Aug 8, 2011 | 10:50 PM
StanleyZ's Avatar
StanleyZ
Sounds like you should have gotten employee of the week for figuring that one out.
Old Aug 9, 2011 | 09:27 AM
wp6529's Avatar
wp6529
Agreed. Connectors are the #1 source of problems for all things electrical and electronic, but without them things are rather unservicable.
The key thing to remember is not to blindly trust that the sensor readings being reported are accurate and to do what you can to independently validate them.
