93 F150 Led Headlight Problems
Old Apr 5, 2021 | 11:42 AM
Hudsonpurdy's Avatar
Hudsonpurdy
Hi everyone, so I've installed some new Led head lights on my 1993 ford f150 5.8. After installing i went to turn on my lights by pulling the light switch out (on) while the ignition is off all is good high beams work, low beams work but when I push the light switch in my tail, front side lights and dash all stay on unless I pull fuse,relay or disconnect the battery. When I have the ignition on while the light switch is on I have only high beams with no indicator of high beams on the dash and can't toggle low or high. I've tried disconnecting all the leds and basically returning it to factory with no success, I've checked fuses all are good even replaced most with new just to be sure and checked relays, I've pulled light switch to check if burnt or anything and nothing looked bad. I have no clue where to start or what could be wrong. Had no previous issues at all with lights. Thanks everyone!
Old Apr 5, 2021 | 02:46 PM
Franklin2's Avatar
Franklin2
If you change ALL the lights back to normal factory lights, those problems should go away. That is the lights in the rear, the side markers, etc. It's obvious that the LED's are causing a problem, since it worked ok before. If you can change everything back and it works, you will have to install load resistors with your new lights.
Hudsonpurdy
Apr 6, 2021 03:16 AM
Jordan.34501
2004 - 2008 F150
Sep 15, 2015 07:34 AM
islanddave
16
Jul 23, 2007 11:34 PM
wagon burner
1997 - 2003 F150
15
Oct 21, 2004 09:18 AM
JJz400
Oct 6, 2003 11:15 PM
