Lights
Old Sep 11, 2015 | 11:13 PM
Jordan.34501's Avatar
Jordan.34501
Lights
ok so here is the deal. i have a 2004 ford f150 heritage edition. This evening i installed some new Sylvania headlight bulbs. I noticed when i went to drive my truck this evening i had no dash lights, running lights, and brake lights. On top of these two problems my headlights were staying on even when i turned the switch off. I am wondering if these new headlights are too powerful or what. I did a spot check on the fuses and they seem to be ok, but i am going to put a test light on them tomorrow. Any idea on what is going on?
Old Sep 14, 2015 | 10:07 PM
steve(ill)'s Avatar
steve(ill)
I would unplug the new head lights and check the dash/ tail lights again.. It sounds like a light switch problem, but possibly tied to the head light plug in ? Try dash / tail with NO head lights ....... check plug in ...switch may be a concidence.
Old Sep 15, 2015 | 07:34 AM
projectSHO89's Avatar
projectSHO89
More information is needed.
Which SPECIFIC Sylvania bulbs were installed?
Is the truck equipped with auto-lamps, DRL, or both/neither?
Are all of the following out of operation? Low beams, high beams, flash to pass?
Does the high-mount brake light still work or not?
Do the turn signals and emergency flashers still work or not?
rockpile
Jun 18, 2016 04:38 PM
rivet96
Mar 26, 2010 11:30 PM
islanddave
16
Jul 23, 2007 11:34 PM
kdmeyer73
1983 - 2012 Ranger & B-Series
Aug 27, 2004 01:24 AM
