Tuner question
BTS is maybe expecting OEM tune? Brian can help with that issue.
If you’re happy with the way it shifts and runs then I say keep it.
If it shifts too hard or you’re looking to change up tunes quite a bit then I recommend the Hydra.
The Hydra hardware is supported by many tuners. So you can try “custom” stuff from various guys. It also has free access to the PHP library of tunes (for stock injectors).
DP hardware is stuck with DP tuning. So if you don’t hit a home run with them then you’re stuck.
Hmmm... So many options! haha.
Yeah shift on the fly is the way to go when you’re ready. The Hydra is only $300 when using the free tunes so won’t break the bank completely. Way nicer than a flash tuner! If it’s shifting hard then you may want to do this change sooner than later.
Be sure to do some research on cleaning the PCM connector before tackling the job. You have to get ALL the silicone off, even between the solder. But you also don’t want to remove any of the solder...
I’m using an old CTS monitor for some gauges. Not sure what setup you have but you’ll need EGT, boost, and fuel pressure separately or buy special sensor add-ons for the CTS. I have Auto Meter for fuel and boost with the pyrometer sensor in the CTS.
Check out the tech folder at the top of the our sub-forum. It has a wealth of information. https://www.ford-trucks.com/forums/1...-7-3l-psd.html
You may want to consider starting a thread to detail your truck and share some photos... the guys around here love photos! This way we can give better suggestions based on your current setup and goals.
Two warnings
1- PMS is a hard addiction. (Powerstroke Modification Syndrome)
2- We love to spend other people’s money
Two warnings
Two warnings
1- PMS is a hard addiction. (Powerstroke Modification Syndrome) Yes it is!
2- We love to spend other people’s money Yes you do!
Two warnings
What's the easiest way to get the PCM code? I have tried to look with a mirror but haven't been able to find it yet.. Doesn't appear the PCM is super hard to pull, but trying to find an easier way if I can.
Guess I'll have to find out how far I have to remove it for California smog as well....
I've got to get some more pictures and make a post. So far I've got oil, transfer case, and transmission fluid and filters all changed (no filter on the transfer case obviously), going through and checking things out, but so far super happy with it. I'll have to start digging into tech folder, currently trying to decide what I want to do with the coolant...
