Sponsored by: Auxito
transmission problems
Old Mar 27, 2021 | 04:47 PM
Daniel Dennis's Avatar
Daniel Dennis
2000 f150 xlt 4.6 2 wd so the short of it is i changed transmissions now it wont run right throws codes (11) most concerning is 1747 which is torque converter electrical system failure im not a mechanic tho i do most of the work on my truck but this is outside my mechanical understandings so i ask is there anything i can do to remedy this and get my truck on the road again... these are the codes . p 1747,po750,p0755,p0743,p0443,p1451,p0135,p0141,p01 55,p0161,p1409, ive looked them all up but have no idea where or how to approach it... help please.... thanks.
Old Mar 27, 2021 | 08:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have several codes for electrical circuit faults. I think you damaged a wiring harness.
Old Mar 27, 2021 | 10:58 PM
70f100longbed's Avatar
70f100longbed
Yes what Mark said. You pinched the harness installing the trans.
Old Mar 27, 2021 | 11:57 PM
Daniel Dennis
thank you for the replies on my issue ill check into it in the am. should i replace the whole thing or try to find the issue? thanks again
Old Mar 28, 2021 | 08:54 AM
Mark Kovalsky
That depends on how bad it is, plus what your skill level is in repairing wires.
Old Mar 28, 2021 | 10:27 AM
FN150's Avatar
FN150
did the same thing when I put in my new tranny. Thankfully we found the problem and it was a quick fix. Wish you well.
djed
25
Apr 15, 2020 11:12 AM
crazyodaz77
May 19, 2019 09:33 PM
madMatador78
17
Jan 16, 2016 07:40 PM
julienf
Nov 13, 2013 10:26 AM
bmoran
Feb 13, 2007 11:58 PM
