Cooked 4R70W???
Old Feb 19, 2006 | 10:28 AM
bmoran's Avatar
bmoran
Cooked 4R70W???
I just purchased an 01 F-150 4.6L 2wd automatic that has no forward gears -- reverse works fine. I pulled the transmission codes and it showed 8 different codes including a couple of codes for stuck torque converter, failure of a couple of shift solenoids, temperature input over and underrange, and overheating. After clearing codes I still get codes for temperature input underrange and overheating on a truck that isn't running. Fluid is at correct level and doesn't look or smell bad (not great but not "cooked").
The wiring appears to be intact and the engine runs fine.
I realize that I'm looking for "devine intervention" but I thought I would ask to see if there are any simple issues that would cause these symptoms or if a replacement/rebuild are my only options.
Don't laught too hard -- just tell me if "cooked" is the correct diagnosis.
thanx!!
Old Feb 13, 2007 | 11:58 PM
croweagle's Avatar
croweagle
i have the same problem with my truck it is a 2001 supercrew f-150 codes 712,713,714, 743 sounds to me the clutch assembley inst gettine any power . electrical problems. tranny not blowen dont rebuild untill you have it checked out
bert cook
Oct 29, 2014 07:53 AM
77_F150_4x4
May 13, 2014 01:36 PM
maddogjohnson
13
Aug 11, 2012 01:28 AM
Halfbad
Bronco II
May 4, 2010 11:47 AM
cmpd1781
46
Dec 7, 2007 10:03 PM
