perdels?
Old Mar 27, 2021 | 02:36 PM
Listor's Avatar
Listor
Well crap there is no small pin in my ipr!
eveything I have watched says there should be but there isn’t
nevermind I found it it was gunned inside the barrel
panicked myself badly there
Old Mar 27, 2021 | 05:34 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Good luck finding that little pin if ya drop it.
Make sure it is oriented properly on reassembly.
Old Mar 27, 2021 | 05:38 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Listor
Found this between the ipr coil, could this have been an issue, going to rebuild anyway but was wondering
Between the coil and what?
Looks like a piece of really old and really bad beef jerky...
I have never rebuilt an IPR, but I trust that David has good advice for you after watching several videos on the procedure.
Old Mar 28, 2021 | 07:05 AM
Listor's Avatar
Listor
it was a piece of the cloth tape from the wire loom, Apparently someone has had the ipr off before
Old Mar 28, 2021 | 07:12 AM
Listor's Avatar
Listor
I did find the pin, it was inside the barrel that i had not removed yet, i could not see it in there . i tried to shake and tap it out but it didn't move ! Freaked me right out, lol
everything is back together, took a couple turns of the key and some cranking to get oil back into the hpop, took it for a drive to work any air out
had grandkids coming over so i didn't get to play with the old girl, i will take some time today
From what i was able to tell it runs better , i could not feel the issue so i am assuming rebuilding the irp did the trick, more testing to come!
I want to unplug the icp and see what i feel, Jeff had suggested that before and it highlighted the ipr issue, i will try it again as a means of feeling it again or not!
might even put the forscan back on it, see if the Bart Bobble is gone
Old Mar 28, 2021 | 10:44 AM
BWST's Avatar
BWST
Got Data?
Very glad to hear your experience on this IPR rebuild. I have yet to do it as well - have the kit ready when needed, assuming the coil does not go first. I'd love to see the after IPR rebuild FORScan data if you'd like to post it. But seat-of-the-pants drivability seems to be showing good results on this repeatable issue. Nicely done, Listor!
Old Mar 28, 2021 | 12:26 PM
Listor's Avatar
Listor
Took a good ride this morning after the grandkids left, very pleased with the results! let me know what you see !
haha no more Bart Bobble!
And i will again Thank BWST for the help and guidance along the way here!
Note: For anyone else doing this > put a catch pan down under the bell housing or your going to get told off for the mess your about to make!
Ask me how i know!
File Type: csv
Old Mar 28, 2021 | 02:07 PM
BWST's Avatar
BWST
Got Data?
This data confirms it. ICP is following the movement of the commanded IPR%.
Glad to help, Listor. Thank you for figuring out FORScan and logging this data. Now if we could just determine out how to get PERDELs to show up! At least you don't need that information to further diagnose this particular issue.
Old Mar 28, 2021 | 05:55 PM
Listor's Avatar
Listor
lol 1 issue at a time , yes even I can see icp ipr and rpm is working together, feels much much better too.
alpha/omega
Offroad & 4x4
3214
Dec 3, 2014 05:41 AM
peter.jones
2009 - 2014 F150
May 5, 2009 08:17 PM
Fomoko1
Canadian National Chapter
Oct 30, 2008 07:25 AM
Labrador
2004 - 2008 F150
Mar 24, 2004 05:57 AM
