Clock Spring Wire Hijack
Old Mar 22, 2021 | 08:49 PM
FrankBrum's Avatar
FrankBrum
Hello from Wisconsin.
I'm looking to add shifter buttons to the rear of my steering wheel. My 2013 XLT has the column shifter, with the buttons waaaay over there.
My thoughts are that the lower 2 buttons on the right, of my steering wheel, I never use. I want to find the wires to those buttons, inside the wheel, and repurpose them to my shift buttons, with some tiny wires.
Then, find the wires that they lead to, on the other side of the clock spring to run out and snip/solder into the existing shift button wiring.
Can anyone share a wiring diagram or two to guide me?
And how does one get into the column shifter itself?
Thank you
Frank
Old Mar 22, 2021 | 09:05 PM
RLXXI's Avatar
RLXXI
Thank you
Frank
Well, it's a little more complicated than wiring runs as there are only 2 wires for all of the buttons that control the audio system on the steering wheel, each button has a different resistance value when pressed that the audio module is programmed to understand which function is being selected by said value it reads and in turn provides the desired function.
I remember reading about someone adding paddle shifters of sort to the steering column shroud just behind the steering wheel and then running those wires from the stalk switch over to them. Was in another forum I forget which. The paddles are stationary and IIRC were from a pc game controller of some sort? Been a long time since I read about it.
Everything in these trucks is computer controlled.
Old Mar 22, 2021 | 09:08 PM
FrankBrum's Avatar
FrankBrum
Ok. Then that's not gonna work like I thought.
And stationary isn't what I'm looking for.
Thanks for the information.
emeraldcoupe
Jun 3, 2015 02:21 PM
51f1truck
13
Jun 30, 2014 10:58 AM
old rat
May 13, 2012 09:56 PM
smihans
20
Dec 23, 2006 12:40 AM
DRanchero
Feb 11, 2005 11:09 PM
