Shift Collar Pic
Old May 12, 2012 | 05:38 PM
old rat's Avatar
old rat
Shift Collar Pic
Does anyone have a good diagram for disasembly of the shift arm at steering wheel ?
Old May 12, 2012 | 06:55 PM
mountainsportsman's Avatar
mountainsportsman
No diagram, but I've done it a couple of times. Pull the steering wheel, unplug the wiring harness, then undo the thre hex head bolts from the bottom holding the column together and it comes right off. You have to drive the pin out of the actual collar to pull the shifter lever. good Luck!
Old May 12, 2012 | 11:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Is it 2WD? Here's the diagram from the Ford parts catalog.
Also, just so you know, more info on what you have would be good. There are over a dozen different columns on these trucks.
File Type: pdf
Old May 13, 2012 | 12:10 PM
old rat's Avatar
old rat
Have wheel off and all the rest but how do I get the collar off without cutting the wires. Plug is too big to pull up through column.
Old May 13, 2012 | 04:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
It's a little tricky but you need to take the wires out of the plastic plug.
Make a diagram of the wires location in the plug. I'm doing this from a very foggy memory, been years since I've had to do this. There is a red plastic insert that you remove. IIRC then each wire terminal has a small tab that has to be depressed to remove the wire from the plug.
Tie a string to the end of the wires so you can pull them back through when you go to reinstall.
Like I said, this is coming from a very foggy memory. If I'm wrong someone please correct me.
Old May 13, 2012 | 05:35 PM
old rat's Avatar
old rat
Thanks. Will attempt it.
Old May 13, 2012 | 09:56 PM
mountainsportsman
Yep, that's the correct way to remove the plug.
Anthony s baca
1997 - 2003 F150
Jul 2, 2014 06:40 AM
51f1truck
13
Jun 30, 2014 10:58 AM
RVABigGreen
Jun 27, 2010 04:32 PM
93f350
Nov 26, 2006 10:13 AM
