Skip pre-heat start?
Old Mar 20, 2021 | 07:44 PM
cat-alac's Avatar
cat-alac
I thought my previous 6.7s you could skip the engine preheat function? Maybe my memory going bad anyone know on a push button 2021 if you can skip the preheat?
Old Mar 20, 2021 | 07:55 PM
4wd6.7L's Avatar
4wd6.7L
I've never heard of this, what is pre-heat start? I know of the start delay in very cold temps.
Old Mar 20, 2021 | 07:56 PM
C12H24's Avatar
C12H24
Pushing the "START" button is just your suggestion to the PCM that you'd like to start the engine. If it agrees with everything, to include the glow plug heat, then it will crank. You can't skip anything since, again, the computer controls what happens and when.
Old Mar 20, 2021 | 08:13 PM
cat-alac's Avatar
cat-alac
I’m sure on my previous 6.7s you could skip it I can remember how though, my dodge you just hit the start button a second time, was thinking previous fords you held the start button down longer.
Old Mar 20, 2021 | 08:25 PM
morleyz's Avatar
morleyz
Is there even enough time on your 2021 to do something that skips the glow plug warm up? When it was 20 below I could probably count to 2 for my 2020 to start. Above 10 it is just about instant.
Old Mar 20, 2021 | 08:51 PM
sky Cowboy's Avatar
sky Cowboy
I haven't seen a way to skip it.
But even if it was possible, why would you want to.
If it needs glow plugs on, let them do their job.
Old Mar 20, 2021 | 09:08 PM
cat-alac's Avatar
cat-alac
This 2021 must have a nanny level setting for the glow plugs heating, my previous ones started instantly this one today for example was 50F and it went into delay before it started.
Old Mar 20, 2021 | 09:12 PM
4wd6.7L's Avatar
4wd6.7L
That is kinda strange. The lowest temps my truck has seen have been 20's a couple times, if there was a delay it was so brief that I didn't even notice it. Started in the 40's and 50's many many times without any delay.
How long is the delay you are experiencing to make you actually want to skip it?
Old Mar 20, 2021 | 09:30 PM
Killer-Bimmer's Avatar
Killer-Bimmer
If it’s actually taking a long time; maybe an issue and that’s a maybe as my ‘21 is pretty much instant and has been between 35-50F since I picked it up in December. Coldest was 25F and maybe 2sec delay and that was remote start which is a slight delayed anyhow.
Old Mar 20, 2021 | 09:33 PM
cat-alac's Avatar
cat-alac
Was 8-10 seconds today on 50F.
Old Mar 20, 2021 | 09:47 PM
C12H24's Avatar
C12H24
Your truck is sick. Take it to the doc. Mine is like two seconds at temps in the 30s.
Old Mar 20, 2021 | 09:50 PM
edjunior's Avatar
edjunior
So again, why are you looking to do this? As was said above, if your truck is taking longer than a second or two to start, then something is likely wrong with it, and you should maybe have it looked at. I'm just really curious why you would want to do this.
Old Mar 20, 2021 | 10:16 PM
cat-alac's Avatar
cat-alac
Thanks for the feedback, will have to take it in I guess must have something going on maybe an ambient temp sensor that’s not right,
speakerfritz
Oct 5, 2020 10:14 AM
KeysMako192
Jun 16, 2020 02:38 PM
Vice1391
Dec 19, 2016 01:32 AM
TinyWonder
Nov 8, 2012 09:01 PM
ozzy460
Dec 31, 2010 10:23 AM
