no start cold
Old Dec 30, 2010 | 04:18 PM
ozzy460's Avatar
ozzy460
no start cold
ok had a no start hot problem would start awsome cold. found ipr orings bad. rebuilt ipr. truck started awsome for bout a week. then yest and this morning no start. wait to start lite cycles. do it 3 or 4 times no start. smoke like hell thou. hit w either start up run all day shut off and starts back up no problem. what issue do i have now? like i said started awsome at 0 degrees and now its 20 it wont even fart.
Old Dec 30, 2010 | 06:04 PM
Muktown's Avatar
Muktown
Turn the key on run out to the engine and lay a screwdriver across the two big terminals on the glow plug relay for about 30 seconds and I bet it starts. I think your gpr went bad
Old Dec 30, 2010 | 06:10 PM
RRranch's Avatar
RRranch
And it might be a good idea to replace all your glowplugs now too since you sprayed ether on hot glow plugs. That's not good. I'd rather get towed home than use that stuff in my engine.
Old Dec 30, 2010 | 06:49 PM
ozzy460's Avatar
ozzy460
thank u! il try it
Old Dec 31, 2010 | 03:00 AM
whack&stack's Avatar
whack&stack
agreed gpr is probably the problem i had this problem 2 years ago. i am by no means an advocate for dealer parts i avoid them due to price at all possible costs but this is a part you want to buy OEM the AM ones just burn up trust me i bought 2 before i finally bought OEM and there isnt that much price difference between the 2 to start with just spend a few more dollars the first time and save yourself the headaches that i went through
Old Dec 31, 2010 | 04:39 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
YUP, glow plug relay, next whatever you do, do not use either, that stuff will blow your engine, just hold a screw driver across the 2 big terminals on the glow plug relay for 30 seconds and fire it up.
Old Dec 31, 2010 | 07:47 AM
ozzy460's Avatar
ozzy460
just did it. started rite up. thank u all.
Old Dec 31, 2010 | 09:10 AM
Muktown's Avatar
Muktown
Don't east your time with a parts store or motorcraft relay. Get a heave duty stancor relay. They're no more expensive and you wont have to change it again
GPR, a stancor part number 802-586-902 SPNO 12VDC at Mouser electronics. $44
Old Dec 31, 2010 | 10:21 AM
ozzy460's Avatar
ozzy460
where do u get them? rite thru ford?
Old Dec 31, 2010 | 10:23 AM
ozzy460's Avatar
ozzy460
nm. haha had a dumb moment. figured it out. thanks
yak
Mar 7, 2015 03:23 PM
cookingguy
Oct 16, 2014 08:18 PM
stainlessstroker95
Feb 8, 2014 10:33 AM
lilbob1131
1978 - 1996 Big Bronco
May 8, 2007 01:42 PM
frty7ford
Feb 12, 2005 04:08 PM
