Rust Repair
Old Mar 19, 2021 | 09:55 PM
Butch5's Avatar
Butch5
Rust Repair
Hi,
I've got some rust on the door pillars of my 96 Ranger. It's the edge where the door insulation mounts. It's the flat edge that is rusted. Part of it is gone. I'd appreciate any ideas on how to fix it. I took it to the body shop. One wouldnt fix it and the other said they could, but didn't sound too convincing. They said they could do something with it. I'm thinking I may have to do this myself. I'm not a welder but I think adding metal via a weld would he the best choice. Thoughts?
Thanks Butch.
Old Mar 19, 2021 | 10:10 PM
RustGuy's Avatar
RustGuy
A pic would sure help to determine the best route. I've taken a cordless grinder with cutting wheel or a Sawzall to a few Pic n' Pull yards and cut pillars, rocker panels, rear corners and all manner of sheet metal. Depending on how compromised the pillar is it might be better to cut out the cancer and weld in a new section. You say you aren't a welder but that's probably your best and strongest option if it's really bad.
Old Mar 20, 2021 | 10:36 AM
mfp4073's Avatar
mfp4073
Pics are needed. Im scared that if 2 body shops couldnt/wouldnt do it that there may be a structural safety issue going on. thats not something an armature welder should be learning on.
Old Mar 20, 2021 | 04:36 PM
Butch5's Avatar
Butch5
Originally Posted by Butch5
Hi,
Thanks Butch.
Thanks Guys,
The rust isn't a s bad as I thought. I've really got to figure out how to stop it so it doesn't return
I'm including a pic of the rust. I'm wondering if I can repair it with bondo or is there something better? I thought about maybe using brazing rods to build it back to the original shape. It's just the flange that the weatherstrip goes on. The door pillar itself is structurally sound. I suspect it's too small a job for the body shop to mess with. The place that said they could something with it was charging about $250. The other place wanted over $1000 to fix the other side which is much smaller that the side in the pic.
GM4WALLS
19
Feb 16, 2013 10:41 AM
300 Buster
Paint & Bodywork
May 9, 2010 11:24 AM
edub32
Mar 9, 2008 05:18 PM
rwsam
1978 - 1996 Big Bronco
Mar 19, 2002 09:45 PM
lastchance
Paint & Bodywork
Dec 20, 2001 04:10 PM
