Radiator differences
Old Mar 15, 2021 | 11:40 AM
PossumTruck's Avatar
PossumTruck
The radiator in my 86 has been successfully held together by stopleak for a year or so, after it began weeping there the core meets the top tank/cap deal. I happened to come across a good/used radiator from a newer model, and picked it up. The only functional difference appears to be that the new radiator is provisioned for an oil/transmission cooler, where my rig has none.
My radiator is all metal - top and bottom caps (inlet/outlet tanks? I don't know the technical term). New radiator seems like plastic on the top and bottom. Also, seems the core might be a different metal?
As in, the 86 looks like...patina all over, including the core. The "new" one looks like a shiny core with black plastic ends. I'm not saying the caps are definitely plastic, it just looks that way.
Old Mar 15, 2021 | 12:30 PM
DarkOverCast's Avatar
DarkOverCast
That's just the newer replacement style, plastic tanks and an aluminum core. I don't like those styles, they don't last
You can take your old rad to a radiator shop and they'll pressure test it and solder any leaks for usually around $75
Old Mar 15, 2021 | 12:39 PM
ford390gashog's Avatar
ford390gashog
That's a standard cheap replacement. Plastic tanks crimped to a aluminum core. They do crack, weep and leak. If you do have a radiator shop the stock one is worth repairing if the core isn't plugged. You can't rod out these core because of the turbulators in the tubes. There is the other option of the full aluminum welded radiator like the 4 row from champion.
Old Mar 15, 2021 | 04:46 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I have been hearing the 4 core Champ ain't so good, I'm told the 3 core Champ is the better choice.
it don't make sense to me either as Champion claims the 4 core will dissipate more BTU's
BUT I get that it might be overkill..... https://championcooling.wordpress.co...four-row-core/
Personally down here in South Texas I don't think Over kill is an issue
EDIT: ya might read this too https://www.oilburners.net/threads/c...diators.83380/
Old Apr 7, 2021 | 07:55 PM
Prototypemech's Avatar
Prototypemech
I purchased a 3 core champion aluminum radiator for my 1994 ford f350 idi and immediately noticed an increase in my coolant temperature. After driving it around for 2 years, I drove up a steep grade and my engine got uncomfortably hot. So the next day I took my old leaking brass radiator to the local radiator shop and had them overhaul it. I think it was about $150 to have them desolder the tanks, clean out the core, resolder the tanks and repaint it. After i got it installed in the truck, the hi coolant temp problem was immediately resolved. I definately recommend have your old radiator overhauled.
Old Apr 7, 2021 | 11:46 PM
DarkOverCast
This is kind of funny because when these radiators came out they were hailed as "way better than oem" ect ect ect, then rumors starting going around they're not, and now there are confirmed cases like yours.
Glad I stuck with stock. I have a couple spares I need to go get cleaned and resealed as the cores were fine temp wise anyways.
Thanks for putting your experience in. Threads that have updates or other opinions is always nice.
I wonder if the name brand misimoto radiators actually work better than oem...seems they should use alot better quality of aluminum.
Old Apr 8, 2021 | 07:37 AM
RaymondIV's Avatar
RaymondIV
Right, I finally took mine to a radiator shop a few years back for a top tank to core leak and the shop owner gave me a 1/2 hour "clinic" on the various reasons why today's aftermarket ones are all cheaply made crap. Best to have an original one repaired if possible.
Abletobecain
Mar 6, 2020 03:06 PM
SgtOtaku
May 9, 2017 10:21 PM
PSDx3
6.4L Power Stroke Diesel
Jul 15, 2013 08:46 AM
GeneStoner
Jan 20, 2003 07:49 AM
