Radio Woes
Old Jan 9, 2000 | 07:19 AM
Larry's Avatar
Larry
Radio Woes
Got an '88 f-250 4x4 w/AC. My radios' lights for station & clock went out a few weeks ago, but radio still works. Any ideas ?? It's the AM/FM Stereo/Cassette model with 3 ***** for balance, bass & treble. Also, week ago one side sound quit--this comes & goes. Because of AC & heater ducting there's no room to get a paw up in there to fool with wires. Is there an easy way to remove the radio ?? Thanks for any help, folks !!
Old Jan 9, 2000 | 12:17 PM
mr. tazwrench
Guest
Posts: n/a
Radio Woes
sounds like your radio is shot, i doubt it's the wiring. i'd replace it with an aftermarket unit. if you take off the trim around the radio you'll see screws that hold it in.
Old Jan 9, 2000 | 09:40 PM
Superdave's Avatar
Superdave
Radio Woes
Larry, it sounds like the light in the radio just burned out, you can easily replace it. You can get it at the Ford dealer for about a buck. As far as your speaker, maybe just your speaker trying to go bad. Or it may be the radio or wiring.
Old Jan 13, 2000 | 03:59 AM
Paul W.
Guest
Posts: n/a
Radio Woes
I had the same exact problem. Ford radios are famous for doing that. Just replace it with an aftermarket stereo. You will be satified.
Old Oct 12, 2000 | 11:55 AM
bgodkin's Avatar
bgodkin
Radio Woes
get the bulb from the ford house and while you are out get a can of tuner cleaner from radio shack. When I bought my 1990 F150 I had this exact same problem. Pull the top off of the radio and replace the bulb then hose the rheostats for the volume, balance, etc. down with the tuner cleaner. work the ***** back and forth a bunch of times to clean out the contacts in there. do this once more and then let the radio sit for an hour or so to dry the tuner cleaner out good. This has fixed everyone with the problems you described that I have tried. The total price for the tuner cleaner and light bulb should run you about 6 bucks. a hell of a lot cheaper than a new radio. Hope this helps.
Brad
Old Oct 12, 2000 | 01:13 PM
Nate_64's Avatar
Nate_64
Radio Woes
You don't need a new radio- like a couple of others have said, it's just the light. Failing radio lights was standard equipment for these trucks.
Mine went out and I got a bulb from my ford dealer- BUT they said the bulb was not a ford item, but that they ordered it from somewhere else and just kept them on hand because they had such a demand for them. That might have changed since, but I just mentioned it because your parts man might not stock them. I think my bulb was three or four dollars. Bgodkin is telling you right about the clean-up. Might as well do it now rather than later.
You'll need some Torx wrenches to get the radio out. the front bezel just pops off and I think 4 torx screws hold the radio in. It'll take about 20 mins to do the whole thing
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.excite.com/f100
Old Oct 12, 2000 | 01:54 PM
bgodkin's Avatar
bgodkin
Radio Woes
I just got to thinking if you are going to get some tuner cleaner from radio shack you might want to see if they have a bulb too. They are pretty good about having wierd electrical components like that
Old Oct 13, 2000 | 05:30 AM
tamarack69's Avatar
tamarack69
Radio Woes
Thanks for all of the replies, folks !! Problem solved !
Old Oct 13, 2000 | 09:44 AM
slikness's Avatar
slikness
Radio Woes
Bob4RTI
Oct 28, 2019 05:01 PM
DBRodriguez
Jul 10, 2014 10:14 AM
bill57
1997 - 2003 F150
Jun 18, 2014 06:46 AM
tilelayher
2009 - 2014 F150
May 29, 2012 08:45 AM
99xlt4.04x4
1983 - 2012 Ranger & B-Series
Jul 29, 2004 09:44 AM
