Camber bushing woes
Old Mar 13, 2021 | 06:29 PM
Norcalpr's Avatar
Norcalpr
Originally Posted by speakerfritz
so I bought these to adjust my camber.
Am I wasting my time?
I have a camber guage and can do before and after measurements
not concerned if the camber adjustment creates more negative caster since I also have a pinion arm drop kit that will eventually go on that will move the caster back positive.
My question is why are you messing with camber?? If this is 4wd, you dont change camber after a lift, you change caster. Big difference.
Those look right.. cutout goes to the rear to increase caster.
Old Mar 13, 2021 | 06:35 PM
4wd6.7L's Avatar
4wd6.7L
Pretty sure he's basing his need for less camber on tire wear.
So now they do look right, they now look like the ones you've used on Super Dutys?
Old Mar 13, 2021 | 06:39 PM
speakerfritz's Avatar
speakerfritz
Originally Posted by 4wd6.7L
Those are caster shims, sleeves, bushings.... Usually referred to as caster/camber bushings because they will often affect both depending how they are installed(-/+). If you had the box or knew the part# you could look up the amount of camber change they are supposed to provide, if any.
correct
it looks like
1/4 will effect pos camber
1/4 will effect neg camber
1/4 will effect pos castor
1/4 will effect neg castor
berry79
Feb 27, 2021 01:41 AM
sandymane
18
Jul 23, 2018 02:55 PM
BstangBill
Sep 22, 2016 01:48 AM
B Big
Sep 1, 2010 07:56 PM
gotdiesel
Aug 6, 2004 12:08 PM
