Tailgate recall
Old Mar 15, 2020 | 12:07 AM
scottz99's Avatar
scottz99
Veteran: Navy
Tailgate recall
Does anyone know if they have to remove the tailgate when they are performing the wiring recall?
Old Mar 15, 2020 | 12:12 AM
sdetweil's Avatar
sdetweil
I don't think so, mine is locked on and I didn't provide the key when I took it in for this recall
Old Mar 15, 2020 | 12:26 AM
SARDiverDan's Avatar
SARDiverDan
So they make the needed repair and then they don’t even check it to make sure it functions properly?
Old Mar 15, 2020 | 07:29 AM
sdetweil's Avatar
sdetweil
it was a hinge lock, which I did not provide a key for..
mine is the KR, with push button start... so no physical key anyhow
Old Mar 15, 2020 | 08:37 AM
helifixer's Avatar
helifixer
what lock are you using? I have been thinking I need a lock on mine.
Old Mar 15, 2020 | 09:32 AM
sdetweil's Avatar
sdetweil
this is the one I have at the moment.. tailgate lock
i had the pipe clamp, but needed to take the tailgate off too many times
almost never took the tailgate off on my 2012...
Old Mar 15, 2020 | 12:47 PM
scottz99's Avatar
scottz99
Veteran: Navy
That's funny, exactly why I was asking. The recall was done on mine last week. Yesterday I was looking around for the special wrench for the tailgate security device. I can't find it and was wondering if they took it out of my glove box and did not put it back or if I'm having a senior moment and can't remember where I put it; most likely the latter.
This is the device I have. They are located near me; I'll have to run down and get another wrench. Yeah, I know it only keeps honest people honest, but it makes me feel a little better.
Tailgate protector
Old Mar 15, 2020 | 01:15 PM
Mattm400's Avatar
Mattm400
No, they do not have to remove the tailgate for the recall. They replace the switch on the tailgate, and splice into the wire harness on the drivers side of spare tire. So check that real good after they get done. I had to retape all the wiring as they did a crappy job.
Old Jun 20, 2020 | 06:07 PM
tomoran's Avatar
tomoran
I had the same situation with the crappy wiring job. They installed two new connectors which make fishing the wires out when removing the tailgate a royal pain. Also they did not supply covers for the new connectors so I'll have to find a way to seal them up when the camper is loaded.
Old Jun 21, 2020 | 10:43 PM
preppypyro's Avatar
preppypyro
Can someone fill me in on what this recall is? What trucks are eligible for it?
Old Jun 21, 2020 | 11:00 PM
ForCal's Avatar
ForCal
What do you drive?
Old Jun 22, 2020 | 06:48 PM
preppypyro's Avatar
preppypyro
Originally Posted by ForCal
What do you drive?
2018 f350 6.7.
Old Jun 22, 2020 | 07:11 PM
ForCal's Avatar
ForCal
2018 f350 6.7.
"model-year 2017-19 Ford Super Duty F-250, F-350 and F-450 heavy-duty pickup trucks equipped with an electric tailgate latch-release switch mounted in the tailgate handle and built at the Kentucky Truck Plant in Louisville from Oct. 8, 2015 to Nov. 3, 2019"
Old Jun 22, 2020 | 09:38 PM
powersrp's Avatar
powersrp
ooooh. thats me, mine works fine, not letting them hack my wiring up till theres a problem.
Old Jun 22, 2020 | 10:02 PM
speakerfritz's Avatar
speakerfritz
I took mine in for the recall and they couldn’t do it becuase the computers were down.
it seems to me if I drill a 1/8 hole in 2 corners of the tail gate and slide a welding rod down the hole, the gate won’t open.
inveztigating
