Remanned tranny installed but same problem
Old 03-13-2021, 11:03 PM
04 F 150's Avatar
04 F 150
04 F 150 is offline
Originally Posted by Lime1GT
After looking at a wiring diagram; I suggest checking Fuse #33-15amp in the central junction box. It may be blown. That fuse feeds transmission as well as O2 sensor heater circuit.
Awesome
Thank you very much
Old 03-14-2021, 10:09 AM
04 F 150's Avatar
04 F 150
04 F 150 is offline
Checked fuse #32, 33, 34 and all are good so nothing there. I have no clue as electronics are not my strong suit at all. Is there a chance Ive got a pcm issue? Manager at shop said its a possibility. Anything I can do to check/trouble shoot it?
Old 03-14-2021, 01:08 PM
redfishtd's Avatar
redfishtd
redfishtd is offline
While a pcm can fail its often blamed because its the black box boog a loo no one understands . I think exposed wiring and connectors are more likely first .They get chaffed-burnt /chewed/pinched on- especially under truck -corroded -wet salt etc.
Old 03-14-2021, 04:36 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
If you have a multi-meter you can check the wiring harness from the pcm to the connector of the transmission for power. It should be a violet/white wire from fuse 33 to the transmission connector plug, according to my wiring diagram. With the connector removed at the trans you could also check for bent or loose pins. It's best to leave it to someone who knows how to troubleshoot with a wiring diagram as you wouldn't want to do damage to your pcm.
Old 03-15-2021, 09:01 AM
60DRB's Avatar
60DRB
60DRB is offline
I had an issue with a 1995 F-150 and shifting issues similar to what you described. Listen to Mark Kovalsky...
https://www.ford-trucks.com/forums/1...-shifting.html
And find a good shop. Often, good general repair shops can refer you to good places that they recommend for specialty work...like transmissions.
Old 03-15-2021, 09:10 AM
04 F 150's Avatar
04 F 150
04 F 150 is offline
I also got a recomendation from a friend of a friend that it could be the range sensor on the shift linkage at trans. Any thoughts there?
Old 03-15-2021, 11:47 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,606 Likes on 1,076 Posts
It's not the range sensor.
Old 03-15-2021, 12:22 PM
04 F 150's Avatar
04 F 150
04 F 150 is offline
Care to elaborate any?
Old 03-15-2021, 01:08 PM
Mark Kovalsky
I see many codes, but none for the range sensor.
Old 03-15-2021, 01:11 PM
04 F 150's Avatar
04 F 150
04 F 150 is offline
makes sense
Thanks
Old 03-15-2021, 04:20 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
They are wrong. If the light is still flashing it means the problem that is setting the code is still present. While it is true that there is some learning going on, all that is learned is shift feel, i.e., how hard or soft the shifts are. It doesn't learn the new trans to clear the codes.
Without talking to them I can't tell if the shop is lying or incompetent. But I'll bet your problem is that they are one or both of those.
Now that you've spent the money on the remanned trans, you need someone that can diagnose the original problem, which is still present in your truck. I'll bet the place you took it can't do it, but maybe I'm wrong. It is most likely a damaged wiring harness.
AGREE and good advice!!!!
Old 03-16-2021, 01:37 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
A look at all the code disriptions suggest the harness has been damages, burned crossed or grounded.
Complete incompetence by not looking up the codes for an honest look at the possible trouble.
With those codes no transmission will work correctly.
With the codes as shown, it is very unlikely the PCM is at fault for that many different transmision control issues or it could not tell you all the different the codes.
It's like what you would get from people who only turn wrenches and guess the rest.
It always comes back to bite.
If a bad harness is found to be the original problem, the shop owner has to give a little for his incompetent employee working like this..
Good luck.
  #28
Old 03-26-2021, 06:48 AM
04 F 150's Avatar
04 F 150
04 F 150 is offline
Heres an update.
first shop had done the "diagnostic" work and came to conclusion that the computer was at fault. I am obviously fed up with them and took to another shop and they found the issue in 3hrs. Bad connection at plug near computer. Corrosion/broken. Got it fixed and Im finally back on the road.
I learned an expensive lesson and found a great shop for future repairs.
Thank you all for advice. Great forum here
  #29
Old 03-26-2021, 08:48 AM
redfishtd's Avatar
redfishtd
Glad you got it fixed and you didn't have to go thru blaming it on a pcm -that's a lot of money and trouble .
Finding good diagnostic guys is difficult .in every state. Maybe you should name that shop for others in your state.
  #30
Old 03-26-2021, 09:09 AM
04 F 150's Avatar
04 F 150
04 F 150 is offline
Thats a good idea.
Discount muffler & AC in Las Vegas.They were very honest and informative on what they did. I will be bringing any truck I own to them frim now on.
IWH
09-02-2017 05:16 PM
Devilmanak
18
04-07-2013 05:48 PM
weldboy
10-26-2011 07:37 PM
mongo75
1999 to 2016 Super Duty
01-04-2007 04:38 PM
thinksnow
09-01-2004 04:16 PM
Quick Reply: Remanned tranny installed but same problem
