Help!
Old Mar 11, 2021 | 03:47 PM
69/F250's Avatar
69/F250
Help!
1969 f250 with no break lights.
Everything else except the dome light works.
Even the controls for the trailer breaks shows the red light when the break is pushed, trailer light don't come on either.
New flasher switch, headlight switch, break switch. Constant power everywhere I can think to check.
Old Mar 11, 2021 | 03:58 PM
wjwolfe82's Avatar
wjwolfe82
Maybe a grounding problem? Remove the rear tail light housing(s) and check for clean ground connections.
Old Mar 11, 2021 | 04:08 PM
cbrown9064's Avatar
cbrown9064
Did you break your brake lights?
Turn signal switch (brake lights run through there), and grounds. Pretty simple stuff...
Old Mar 11, 2021 | 04:11 PM
69/F250's Avatar
69/F250
New turn signal switch and they worked after I put it in. Ground wires I haven't looked at.
Dylerbiller
Dec 30, 2019 07:50 AM
Vinford
Electrical Systems/Wiring
Apr 9, 2008 09:02 AM
rjmay
Sep 10, 2006 07:11 PM
nomadic
Jul 17, 2004 02:46 PM
plumr
May 6, 2002 01:09 AM
